Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Paint and Bodywork
Old 12-21-2009, 11:04 PM   #1
292farmer
292farmer's Avatar
Best paint & rust removal tool?
i have a 4 1/2in electric grinder 12,000rpm and im wondering what is better for removing paint and rust a wire brush attachment or sand paper attachments? i started my tailgate and i went threw 5 sheets of 40grit in 20mins and only did a10in sq section is that normal? sandpaper was from walmart... should i rough up with wire brush then sand paper then wire brush stubborn rust again? is that normal time frame? implanning on doing frame this winter, and started tailgate to familiarize my self with the tool, and find most effective way. thanks
292farmer is offline
Old 12-21-2009, 11:09 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: best tool?
I would not use an angle grinder to sand the body - it could cause body warpage from the heat of the sander - it will work great on the frame and heavy metal
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline
Old 12-21-2009, 11:41 PM   #3
292farmer
292farmer's Avatar
Re: best tool?
ok thanks was only doing tailgate anyways, i wanted to get used to the tool bought it today, heard they can have kick back so wanted to get used to it, im doing inside tailgate then im rhino lining it after i smooth it out. should a good wire wheel handle the frame? i know its gonna take time, just want to make sure i at least got right tool attachments, i dont have a compressor, and landlord does'nt want chemicals used (understandable) and cant afford a sand blasting, sooo im doing it the fun way.
Old 12-21-2009, 11:47 PM   #4
mtdave2
newly minted old timer
mtdave2's Avatar
Re: best tool?
if you are only doing the tailgate....sandblast! i found a local place that will do things like that for under 100. well worth it imho...
sorry just reread your post...if you are only doing the inside to line the bed...id use a wire wheel. that metal is thick, you shouldnt have a problem
72 c20 longhorn 65k org miles and counting!
69 k10 Suburban
mtdave2 is offline
Old 12-22-2009, 08:07 AM   #5
Re: best tool?
Where`s the landlord?I`d use stripper,Just cover the area around and under the truck to catch the evidence.The wire wheel and coarse sandpaper will leave scratches all over the surface.The paper is getting ate up because of the higher rpm.I use a palm sander is I can`t use a DA.
A wire wheel will work great on the chassis.
special-K is offline
Old 12-22-2009, 10:21 AM   #6
mrein3
mrein3's Avatar
Re: best tool?
Here is what I did do and will do again when stripping a panel down to bare metal.
3M makes a disk called the "Sandblaster". They cost $10 - $12 each. You also need to purchase a $5 "adapter" for your angle grinder. The adapter is reusable (I'm still on my first one) and each disk will last for approximately one panel.
So far I have stripped my truck hood, both fenders, and both doors, both inside and out with this system. They take paint, primer, and bondo off quick and don't warp the panel.
Of course quickly treat the bare metal with epoxy. Or acid then epoxy if it was rusted. And of course wear a respirator when all that paint dust is in the air - you don't know what is in that paint.
If you're like me and have more time than money, these purple pads work great.
I don't work for 3M.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline
