03-24-2011, 10:15 PM | #1 |
trailering a truck???
It looks like I may be coming down on orders in the next 2 or 3 months and I'll need to transport my truck. Depending on where I get sent it will determine if I bring the truck with me or leave it with my folks back in PA.
If it goes back to PA a good friend of mine has offered to come down with his truck and flatbed trailer to tow it back for me. The only thing is...neither of us have trailered a vehicle before. His trailer isn't specifically for towing a vehicle, it's a dual axel flat bed that he loads 20ish 6 man rafts onto. Can that style trailer still be used or will I need to figure out something else? I figure if I cover his expenses it will come out to about what a transporter would cost. If it comes with me I'm probably going to pay out the ass to rent a Uhaul or similar truck to tow it. Option C is to look into what it would cost for an auto transporter to move it and have my folks make a road trip down here to pick up all my parts with their truck.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
03-24-2011, 10:26 PM | #2 |
Re: trailering a truck???
A flatbed dual axle will work fine if the deck is good. I only ever hauled on a metal bed so I don't know about wood, but if it's a metal deck you can haul it all over no problem.
Just be sure to strap it down real tight with good straps, don't take any crazy turns, and be careful. |
03-24-2011, 10:53 PM | #3 |
Getcha Pull
You really need to look at the rating of axles on the trailer, and go from there. Proper trailer brakes are also important. The only other key thing is having a truck big enough to tow the big chebby with.
I suggest reading up on how to properly load a vehicle regarding tongue weight and such, and also investing in good straps.
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
03-24-2011, 10:56 PM | #4 |
it's a wood deck IIRC. The trailer is only a few years old, he bought it when he expanded his business. I know it's got brakes on it too, a load of 20ish rubber 6 or 8 man rafts weighs just as much as one of our trucks and that's not close to the load capacity. His rig is a late 90's F350 with a turbo diesel.
03-24-2011, 11:09 PM | #5 |
Roadtrip!
How far do you need to go with it? I would say if neither of you have any experience hauling something like this, get someone else to do it. (unless it is a short haul) Truck and trailer behind you add around 7-8000 pounds!!
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-24-2011, 11:21 PM | #6 |
We've both towed heavy loads before, just never tied down a vehicle before. I've tied down a skid loader with assorted attachments when I worked landscape construction in college, but there it had dedicated tie down points and I didn't care if I scratched/bent something.
Drive distance is about 600mi
03-24-2011, 11:31 PM | #7 |
I'll let someone else answser the wood bed issue, but for tying it down just strap from the axles (all four corners) to the bed. We have a little frame around our bed that we strap to. If you don't have that I'd weld some on right quick. I can't say I'd be OK with tying it to a flatbed without any side rails.
If you decide not to do it you can go on Uship.com and get a shipper pretty cheap. |
03-24-2011, 11:35 PM | #8 |
I'll check out Uship.com as well once things start to get finalized.
I know for certain that the trailer has a lip around the edge to hook the big tie down straps we used on the rafts. They're usually stacked about 5ft high with the last few partially inflated or fully inflated.
03-24-2011, 11:37 PM | #9 |
Watchin the rust grow
I say go for it. Block all four wheels, strap it down all 4 directions with some chains. If he's got a one-ton truck. Just be patient, relax and take it easy when driving.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
03-24-2011, 11:59 PM | #10 |
its all about the +6 inches
buy a towbar and drag it behind your moving van
03-25-2011, 12:05 AM | #11 |
Whatever you choose, take pix please
03-25-2011, 12:19 AM | #12 |
I'd need to disconnect the driveshaft correct?
03-25-2011, 12:31 AM | #13 |
The guy i bought my truck from hauled it close to 400miles in a 2500chevy gas truck with a wood floor trailer with a small lip for side rails. He strapped the truck on all four corners without any problems. Two on the axle then two up front somewhere also(dont remember exactly where. Just take a easy and dont forget its back there.
1969 Chevy c20(Miss Hackjob) |
03-25-2011, 01:01 PM | #14 |
MOVE OVER
what is the width and length of the trailer? depends on if you can get the truck on it, also will it be hanging out the back of the trailer also if it is too long you have to look at your tongue weight as well.
you dont necessarly have to pull the driveshaft unless it is a automatic tranny, but wouldn't hurt to drop it if you plan on pulling it behind a moving van.
No matter where you are..... There you are... Buckaroo Banzi |
03-25-2011, 01:35 PM | #15 |
Still Truckless!
Did exactly that when I trailered my truck home. Strapped down the A arms up front and wrapped a couple of 5k cargo straps around the back axle. Then just put it in gear if it's a manual and make sure to brake a little earlier.
~James Truckless 2009 Hyundai Sonata<~~Wife's sedanomatic 1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive Founder of The 60-66 Club Tutor Et Ultor |
03-25-2011, 05:28 PM | #16 |
Drop the driveshaft, rig up some tail/brake/turn lights and head out. If you end up going this route, I can post how to make a wire harness that will work slick and cost next to nothing, and some tips on tow bar towing.
People get scared of it, but it's been done forever, and still done today. Safe, legal, cheap, effective. If you tell them that you are triving it, you'll get paid. If you tell them you are dragging it, then it's all out of pocket (this is as of 10 years ago when I got out). |
03-25-2011, 10:00 PM | #17 | |
If there is a harbor freight near by they have those magnetic towing lights on sale periodically for 10 bucks. 20 normally. just a suggestion.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
03-27-2011, 04:23 AM | #18 |
If you put it on the trailer, make sure you check the tie down straps or chains for tightness regularly. I like to do it at 25 miles, 100 miles and then every time you stop for a break.
98 GMC Sierra Ex Cab, cowl hood, Euro LED lights, 30 bar billet, Whipple Supercharged 350 Vortec: Forged flattops, E-Tec aluminum heads, Comp Cam, Scat crank and rods, Granatelli Mass air flow, Headers, Flowmaster exhaust , Complete MSD Ignition, Custom Tuning, intake spacer , ported throttle body, AC Delco port injection upgrade, Roller Rockers, Power Pulleys. Gear Vendors Overdrive. Soon to hit a dyno. 2/4 drop(for now). 95 Chevy S-10 Ex Cab 4.3 5 Speed 2/3 drop, Euro lights, billet grill, More to come. The Daily Driver |
03-27-2011, 01:47 PM | #19 |
Where can I buy a tow bar and how much do they run? If I go that route I can have my folks drag it with their 6cyl frontier. The tow cap is over 6K lbs IIRC
03-27-2011, 07:34 PM | #20 |
e bay usually has them, any RV sales place, some trailer builders/sales place carry them too.
I got my first one at wal mart 10 years ago. The local wal mart told me they stopped selling them about 8 years ago, but a couple guys on here found them at there local wal marts since then. |
03-27-2011, 10:40 PM | #21 |
blood type; Retumbo
tow bars are not hard to make either. I have one I use for my 67.
LHM is the tow-bar king. listen to him. |
03-28-2011, 10:23 AM | #22 | |
Posted via Mobile Device Last edited by Z16; 03-28-2011 at 12:28 PM. |
03-28-2011, 11:53 AM | #23 |
Catchy title goes here..
03-30-2011, 02:29 PM | #24 |
Overworked and Underlaid
I may need to be towing a truck here soon about 200 miles give or take and since i dont have a tow trailer or tow dolly nor do i know of anyone that would let me borrow one would it be safe to use a towbar to take a 78 LWB Heavy Half Chevy which will(most likely)not have an actual engine and trans in it but in the bed of this truck or the one towing will be transporting a 250I-6 and a GM 3spd(whatever came stock in a 78 C10 3ott truck) and it will be towed down from 7000ft elevation to around 1200ft elevation(from flagstaff,az to phoenix,az).The truck that would be towing it most likely would be my other 78 Heavy Half Chevy.Not only would the I-6 and manual trans be part of the load one way or the other but i would transporting some of my other personal belongings too.Is all of this safe to do with a towbar or is it better and safer to go with a tow dolly or tow trailer.
I'd rather push a Chevy than drive a Ford The Beast-1978 C10 LWB Red-1978 C10 LWB (Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012 Gone but will never be forgotten-RIP (Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012 Taken from us to soon but you will live on in our hearts-RIP |
03-30-2011, 03:00 PM | #25 |
Not sure about flat towing a truck, but my dad has towed a lot of vehicles for friend, including my 70 3/4 4x4 suburban and my 70 Blazer 4x4. He has a dedicated car trailer though, but depending on what your buddies trailer looks like, if it is rated for the weight, and long enough, it should be fine.
here is a picture of the suburban being towed by a 99 K1500 suburban with a 350. One thing to remember, is trailer length will plat a large part is towability too. I believe my father's trailer has a 20 foot deck (atleast 18') on it, and as you can kinda see, we had the suburban back so it was centered over the wheels of the trailer. This reduces the tongue weight of the trailer, and reducing the wear on the trucks suspension, as it is doing more towning and less carrying of the weight this way. (You'll notice that the truck isn't squatting, even though it is actually almost undersized for this size load) We towed this truck 120 miles roughly, with several good hills too. The truck/trailer have trailer brakes setup, along with anti-sway bars for the hitch setup, which I feel is a must for towing something this size. As for tying it down, we have two tie downs at the corner in the front and two in the rear. When the truck was put on, we looped two ratchet straps over the axle on each side, and hooked them up to the close side loop and ratcheted them down tight. If you have a smaller trailer, you can criss-cross them if you have a place to loop them on each side where they won't slide. Once the front it tight, we put the ones on the back and tighten them down there. This pulls the truck back, and also tightens the fronts as well. As stated, i would stop after 10, another 30, and then every time you stop (make it a habit) to check the straps. This picture is actually after 5 miles of driving, right before we got on the interstate. We also put the truck in gear on the trailer once it was tied down. I would be weary of the u-haul trailers as they tend to be short and won't allow you to adjust the load Hope that helps. Any pictures of your buddies trailer? There should also be a load rating plaque on the frame of it somewhere.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
