Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Trucks For Sale
Old 09-07-2020, 10:46 PM   #1
HellaciousA
HellaciousA's Avatar
1970 C10 Shortbed Protouring project - No limit frame
https://www.youtube.com/watch?v=6Rd5miSeac8&t=393s
Not happy to be doing this, but I have no choice. Time to let someone else hopefully finish what I've started. I've got a build thread you can view my progress here:
https://67-72chevytrucks.com/vboard/...d.php?t=679611
Body
-Clean title in my name with current CA tags (Note, I did not non-op the truck).
-Frame that came with the truck was not original and was twisted/parallelogram
-Original bed was in very poor condition, no bed included with sale
-Cab was put on a rotisserie and has been sandblasted and epoxy primed
-New inner and outer rockers
-New cab corners
-New smooth cowl panel (fiberglass)
-New custom firewall inserts
-Floors are solid with no rust
-Drip rails shaved
-Cargo lamp shaved
-New doors, hood, fenders, radiator support
-Stainless hardware kit for front end
-Porterbuilt hood hinges mounted on firewall
-Energy suspension cab bushing kit and new hardware
-New windshield
-New flush fit back glass kit
-New Precision weatherstrips for doors
-Ididit tilt steering column and steering shaft
-Original bench seat in decent shape
-High hump transmission cover by Slosh Tubz
Frame/Rolling Chassis
-No Limit C10 Pro-Tech Chassis (*high kick rails in the rear--bed floor will need to be raised)
-Setup for LSX family of engines
-Can mount a variety of transmissions
-Aluminum fuel tank with high flow pump capable of 800 rwhp
-Dual 3/8" fuel lines
-9" Floater rear end with Eaton True Track 3.30 gear ratio, Moser Axles
-Front and Rear Splined Sway Bars
-14" Wilwood 6 piston calipers, rotors and pads, 5 x 4.75 hubs
-14" Wilwood single piston rear caliper with integrated parking brake
-Frame has been powdercoated "Black-Magic"
-4 Link "Fat Bar" with heim rod ends
-Battery box with drop out battery tray (mounts in rear of frame)
-Flaming River road race rack & pinion steering rack
-Frame is set to accommodate up to 10-11" wide wheel up front, 12" in rear
-Total from No Limit for the above parts was $22,000, took 6 months to build
Over $50k invested, willing to sell for $37,500 w/o engine/trans/etc
Engine/Trans details:
Currently has a 6.0 LQ4 from a 2005 HD Silverado and a 4L80E with a Jake's 2800 billet stall converter and HD2 shift kit. Also have a KB Racing turbocharger kit with a Borgwarner S475 Turbo and 1000 hp Treadstone intercooler. I also have an Entropy LS Swap radiator/fan setup, Holley Dominator ECM plus wiring harnesses and sensors, new 80 lb injectors, LS6 manifold and throttle body, Holley front engine accessory set, and many other drivetrain components. If buyer wants the engine/trans/turbo/ecm/etc, add $11,500. Receipts and invoices all available.
Located in Chatsworth, CA
Andrew
1slogoat@gmail.com
1970 C10 Short wide
-No Limit Pro-Tech Chassis 6.0 LQ4 / BW S480 Turbo
2004 Pontiac GTO, 419rwhp/378rwtq, -H/C/I/E, M6
2014 Cadillac CTS-V Auto
HellaciousA is offline   Reply With Quote
Old 09-07-2020, 10:53 PM   #2
HellaciousA
Re: 1970 C10 Shortbed Protouring project - No limit frame
1970 C10 Short wide
