12-01-2022, 12:52 PM | #1 |
Rough idle at start.
I continue to have a ridiculous idle on a cold start. I live in south Florida, so I don't mean freezing temps, just sitting over night. It is a crate 350 engine 350/290 4 bbl Q-jet. It seems like only running on 1/2 the cylinders. But If I put it in gear it idles perfectly. Once it gets a little heat in the engine it runs fine. Carb has been rebuilt and it and the choke function as designed. Oh, and it is lucky to get 8 mpg. The original engine got 11-12 mpg. I have heard I need a different torque convertor, but that would have nothing to do with the idle. And once started, and warmed just a tad, it will continue to run fine all day long.
12-01-2022, 01:02 PM | #2 |
Re: Rough idle at start.
Can you post a photo off the carburetor with the air cleaner removed just after starting it cold? That will help us determine what the issue may be. If you can frame the photo like this one it would be great.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
12-01-2022, 02:11 PM | #3 |
This is the picture after starting. Ther engine is running and kicked off fast idle.
12-01-2022, 02:18 PM | #4 |
Flip fa ya...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
12-01-2022, 03:16 PM | #5 |
It appears that the fast idle cam is in the midway position. Which is good. Meaning that you should be able to turn the fast idle screw in and raise the idle to help smooth things out.
First photo see your fast idle cam position. Second photo see the cam completely down. Fast idle adjustment screw is circled in last photo. Try turning the fast idle up before changing other settings. The RPM should be in the 1000 to 1200 range.
12-01-2022, 03:45 PM | #6 |
I'll give that a try.
12-01-2022, 05:39 PM | #7 |
Maybe a bit too much choke pull off at cold start?
12-02-2022, 12:37 PM | #8 |
I agree that starting with the carb fast idle is most logical. Most quadrajets just need the proper love and setup. However, there's a whole other list of things just to consider after your rough idle is sorted...
These crate motors are really low compression. They seem to like a lot of timing... in the 14-16+ range i've found after messing with 3 or 4. The engine break in instructions call for weirdly low static timing, and no vacuum advance. Great in theory for racing, and punishing for fuel mileage. The cam in that 290hp motor is nearly too much for the low compression, and i'd argue the lobe centerline is all wrong as well for the compression. If the throttle shafts weren't rebushed on that quad, then there may be a vacuum leak around the throttle shaft. Small vacuum leaks may seem like they iron out after a motor warms up, but they can wreak havoc on a cold motor |
12-02-2022, 03:12 PM | #9 | |
Who Changed This?
