Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > S10 S15 Luv Blazer Classifieds
Old 07-03-2018, 05:43 PM   #1
Ironhorse
Ironhorse's Avatar
S-10 Drive Shaft Needed
Asking for a friend of mine. He has an '01 S-10 with the 4.3 V-6, automatic trans and extended cab. It has a 2 piece drive shaft and he is needing the rear section. Any one parting out such a truck? Has not been able to find one locally. The Cash for Clunkers and the previous high scrap steel prices sent a lot of parts truck to the melting pots.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 07-17-2018, 10:44 PM   #2
joedoh
joedoh's Avatar
Re: S-10 Drive Shaft Needed
the 01 V6 extended cab is a flange pinion mount with a double cardan rear section. thats a real needle in a haystack, and most used units will have the same problem (the double cardan is worn out). I sold just the rear section of one for $150 from a low mileage truck a couple years ago and could have probably asked twice as much with how much my phone rang. you cant easily convert to a one piece because of the crossmember and the proximity of the driveshaft to the floor. plus the length of a one piece can cause problems (harmonics). some guys have converted to the 2wd 4 cylinder ext cab driveshaft which doesnt have the double cardan, but I think you need to change the pinion too and I really have no experience with that swap.
midwest driveshaft http://www.mdsdriveshaft.com/gmc.html sells a replacement with or without the double cardan but its pricey. I have had good luck with driveshaft work at inland truck parts on west k42, their driveshaft guys are great, they call my s10 stuff "toothpicks". dont go in the main door, there is a "driveline shop" door to the left.
Old 07-18-2018, 04:29 PM   #3
Ironhorse
Ironhorse's Avatar
Thanks for the reply. My friend's problem is the rear section of the drive shaft has a pretty good sized ding (aka dent) in it and is causing an imbalance and a vibration when driving. Being retired and on a small income he is hoping to find something that will work for him from someone parting out a similar S-10. Has not been able to find anything locally.
Wellington, Ks
Old 07-21-2018, 03:06 PM   #4
joedoh
joedoh's Avatar
if his double cardan is good, inland can repair (if needed) and rebalance the driveshaft. a cut and balance no u-joints usually runs me $125, so that might be a good guide.
they will probably want the whole thing, and those arent the easiest to pull. best advice I have for removal is to take the axle/sping u bolts out and pull the axle back a few inches. if you dont, the driveshaft will come very close to coming out but wont. doing it this way also makes it easier to separate the flange from the pinion.
if you need a yoke for the trans to keep all the fluid in I have one he can borrow. I am just north of wichita.
oh one more thing, if he has lowered the truck with blocks, his vibration is likely the center bearing needs shimmed.
Old 07-22-2018, 09:33 AM   #5
Ironhorse
Ironhorse's Avatar
Thnaks, will pass the info along.
Wellington, Ks
Old 09-10-2018, 03:00 PM   #6
GRADYS Performance
GRADYS Performance's Avatar
Are you still looking for this part?
GRADYS Performance is offline   Reply With Quote
Old 09-10-2018, 06:42 PM   #7
Ironhorse
Ironhorse's Avatar
Called and talked to my buddy and he is still looking for a drive shaft. Is your drive shaft complete, both pieces, just the rear section ....? What are you asking for it? Can you post a picture to the board? Communication will be some what slow as he does not have a computer. He is retired on SS so cost of items is a subject for him, hope you understand.
Wellington, Ks
Old 09-17-2018, 11:34 AM   #8
GRADYS Performance
I will check this weekend to make sure it is still available and try to get a picture. It is the whole driveshaft. Only cost would be to ship it to you or him. It is used it may need joints etc.
