Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 10-06-2009, 08:43 PM   #1
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
my 99 V-8 swap
had 2.2, bearings went out, mocking things up... got Trans-Dapt 9906 mount kit and Hedman shorty direct fit headers #69520 kit. massaged the fire wall some on the pass. side to clear flange. looks like drivers side it good. steering shaft goes through the drivers side header.
thoughts? advice? pointers?
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 10-06-2009, 09:43 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: my 99 V-8 swap
Nice pictures!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-07-2009, 10:11 AM   #3
bigbadjohn84
Re: my 99 V-8 swap
sweet. Ive always wanted one of those light weight dummy blocks to do mock ups. just could never justify the extra dough. will follow
bigbadjohn84 is offline   Reply With Quote
Old 10-07-2009, 09:14 PM   #4
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
set the tranny in to see how it'll look/fit gotta build a cross member to get me some room for exhaust. but all looks promising.
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 10-07-2009, 09:15 PM   #5
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
4 degrees of slope in the tranny, I think that'll work
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 10-07-2009, 09:22 PM   #6
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
some exhaust fabbin pics...
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 10-08-2009, 05:16 PM   #7
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
tranny crossmember
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 10-12-2009, 09:55 AM   #8
Myself
Re: my 99 V-8 swap
Go ahead and trim the ears off the trans bell. If you ever need to unhook the headers it will be easier. Those two studs hanging from cab floor make a nice place to mount a driveshaft safety loop. Pull your carpet back and mount some of that heat reflective stuff under it from the firewall back about 1/2 way on the floor. The headers will cook your feet on long trips. Don't cheap out on your cooling system, go aluminum water pump and radiator. You'll be glad you did. That's all I can think of right now.
Myself is offline   Reply With Quote
Old 10-18-2009, 09:50 PM   #9
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
some more progress
i gotta get a radiator, alternator, A/C compressor (Or a delete pulley for now) but its coming together
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 10-19-2009, 06:35 AM   #10
68C15
blood type; Retumbo
68C15's Avatar
Re: my 99 V-8 swap
a word of advice on the AC compressor. do NOT buy reman. you might as well get a used one. same quality and cheaper. I recommend getting the Sanden replacement unit. I did mine and will never look back. get the compressor kit. it comes with ICE32, the compressor, correct oil, accumulator, and all O rings/seals.
I got mine from T & A service here in SF. ~$275
68C15 is offline   Reply With Quote
Old 10-20-2009, 07:55 AM   #11
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
i was thinkin pulling from the junk yard for now, get the compressor the hoses...
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 10-20-2009, 04:27 PM   #12
clinebarger
Re: my 99 V-8 swap
chevy2racr. Your not concerned about emissions regulations? one day emissions testing WILL be nationwide.
clinebarger is offline   Reply With Quote
Old 10-20-2009, 06:47 PM   #13
chevy2racr
chevy2racr's Avatar
Re: my 99 V-8 swap
well theres no big hurry here...
71 C10 with 454
09 Malibu
Marshalltown, Iowa
