Old 12-20-2009, 06:27 PM   #1
handymanmac
Help!!
I replaced the intake manifold gaskets on my 95 GMC 305. Previously I had just changed the wires, cap rotor, plugs egr ignition module. I put everything back together and now it wont start. Got fuel, and spark but wontfire. Trouble code I get is #35 for IAC sytem. How do I check the IAC module and would that cause a non-fire situation?
mac
handymanmac is offline   Reply With Quote
Old 12-20-2009, 07:47 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Help!!
I guess by "fire" you mean it won't start but if you get spark plus fuel you should have combustion in my experience. You might want to double check the firing sequence and all the spark plug cables for cross firing.
68gmsee is offline   Reply With Quote
Old 12-20-2009, 08:05 PM   #3
handymanmac
Re: Help!!
I went through everything figured it had to be timing or spark. I pulled the coil of of one of my other trucks and it fired right up. Might have been a bad connection or a bad coil but I'll find out tomorrow when I put the other coil on the opposit truck. Thanks for the reply
