Old 05-19-2002, 07:27 AM   #1
Joe71Cheyenne
Question lowering Springs
I used lowering springs on my 71 cheyenne 3&4" when I lift the truck off the ground the springs get loose and fall to one side, to lower the truck I have to hold them in place and lower it is this normal? Thanks Joe
Joe71Cheyenne is offline   Reply With Quote
Old 05-19-2002, 07:36 AM   #2
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
There is nothing you can do except get drop spindles. I heard that you can remove the upper bump stop on the upper a-arm and run a bolt through there instead. Just use a very long bolt and when you jack it up it will hit the pod that comes off the frame and won't allow the suspension to sag that far.
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
Aberdeen South Dakota
WANTED: Drop Spindles
F/S: rebuilt Turbo 400 & Aluminum wheels w/ tires
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
