Old 06-16-2021, 01:45 PM   #1
71gmcC15
71gmcC15's Avatar
Factory radio doesn't let me listen to 106.3 fm
I got my factory radio working last night and the radio will not scroll passed 100 fm. One of the presets it set to a channel higher then that but I cant even press it in hard enough to move it passed 100. It moves just a little bit wit a lot of force. Why? Do I need to take it apart or something? On the bright side 96.9 94.1 and 93.3 are still available to me. But I realy like 106.3.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 06-17-2021, 10:13 AM   #2
truckin 79
Re: Factory radio doesn't let me listen to 106.3 fm
Yes you can take off top cover and lubricate it and it should be fine. I lubricate the buttons,on top of the buttons and the arm that moves it back and forth. You can pretty much lubricate any moving part you see except I would not lubricate the little round disc on the right of radio though, that is for the presets.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 06-18-2021, 07:52 PM   #3
71gmcC15
71gmcC15's Avatar
Ok next time I have the dash all blown apart I'll do that. Also figured out if I hit the brake when the pickup is off the radio will come on. No it's not hooked to the brake swich I checked.lol
Old 06-19-2021, 11:56 AM   #4
Keith Seymore
Keith Seymore's Avatar
Ha! That's a feature, not a bug....
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-20-2021, 12:02 AM   #5
71gmcC15
71gmcC15's Avatar
Seriously? Why I dont see the point.
Old 06-20-2021, 02:10 PM   #6
Ziegelsteinfaust
Sounds to me like the radio doesn't want you to listen to that channel.
Rock and roll is the devils music.
It's just trying to save your sole
Ziegelsteinfaust is offline   Reply With Quote
Old 06-20-2021, 05:48 PM   #7
71gmcC15
71gmcC15's Avatar
to bad 93.3 and 94.1 are also rock stations.lol
