Old 03-20-2010, 06:30 PM   #1
jcfoote60
Active Member
jcfoote60's Avatar
1978 differentials
Hey does anyone know if the front and rear differentials from a 1978 1/2 ton 4x4 will fit under a 69-72 Blazer?
Jim
jcfoote60 is offline   Reply With Quote
Old 03-20-2010, 10:29 PM   #2
blazin 70
blazin 70's Avatar
Re: 1978 differentials
The front diff should bolt right in but the rear end will not the spring pads on a 78 diff will have to be cut off and a new set welded on as the widths are different.I am planning on putting newer model running gear under my 71 also.
blazin 70 is offline   Reply With Quote
Old 03-31-2010, 09:17 PM   #3
69BLAZYA
the center bolt holes on the 73 up fronts are about 1/8" off on both sides, I just forced the springs outboardwith a pry bar
69BLAZYA is offline   Reply With Quote
