Old 08-23-2012, 06:37 PM   #1
bigdog57
bigdog57's Avatar
Timing
My baby has been setting for months now because I could not get it started. Its been acting like the timming has been 180 out. I've been trying to get it set (along with several other people). I finally took it in to my mechanic (he is an old school mech.) and sure enough it was 180 out. But its back firing and is checking out why (like and exahust valve isn't working right). This thing sure has a mean learing curve
Bigdog
bigdog57 is offline   Reply With Quote
Old 08-23-2012, 06:55 PM   #2
cleszkie
cleszkie's Avatar
Re: Timing
If your sure you've found TDC on the #1 cylinder, and gotten your distributor dropped in with the rotor on the #1 firing position, you should be able to start the truck, give the dizzy some advance and away it should go. If not, I would pull the valve covers and check the valve adjustments. If those check out, you might have a sticking valve.
cleszkie is offline   Reply With Quote
Old 08-23-2012, 11:09 PM   #3
oklalawnboy
oklalawnboy's Avatar
Re: Timing
I would first make sure all the plug wires are in the right spot 1,8,4,3,6,5,7,2
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 08-24-2012, 02:53 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Timing
I'm gonna guess timing chain.Especially if you didn't pull the dist between when it ran and when it wouldn't start.The teeth sometimes sheer off and allow the valvetrain timing to be out.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-24-2012, 03:19 PM   #5
C5Phil
C5Phil's Avatar
Re: Timing
I agree... happened to me-- back in the day they used nylon covered aluminum camshaft timing gears-- usually lasted 50-70,000 miles - then teeth sheared and timing went to hell..
C5Phil is offline   Reply With Quote
Old 08-24-2012, 05:01 PM   #6
JumboAMONGus
JumboAMONGus's Avatar
Re: Timing
back firing after sitting for long time sometimes just carb gets dirty to or a rubber plug or vacuum leak , i had engine back fire and sputter after sitting then i checked water in radiator and it went ll in the engine ,,lol
JumboAMONGus is offline   Reply With Quote
Old 08-24-2012, 06:18 PM   #7
bigdog57
bigdog57's Avatar
Re: Timing
I have changed the timing chain and sprockets, the hei distributor is new. I am hoping that since ith has been setting for months that the back firing will settle down. Since i just got home i will mess with it this weekend.I figured that the wise people on this board would lead me in a good direction.
Bigdog
