5.3L cam swap
I have an 03 Z71 Tahoe with the flexfuel 5.3L that I am considering swapping in the GM 345hp 6.0L camshaft I have. I was originaly going to use it in the 6.0L swap I had planned but after tearing into the supposedly good motor found the block to be cracked and the machine shop said it was not repairable. So I now have this cam and I am getting the itch to swap it into my 5.3. Just want to know if I can reuse the stock valve springs and push rods or if not what springs and pushrods do I need for this swap?
Thank a Veteran. They have sacrificed more than you will ever know! 2003 Chevy Z71 Tahoe 190,500 miles 2002 Chevy Silverado 1500 4x4 230,000 miles 1987 custom built Silverado 4x4 435,764 miles 1985 K5 Blazer 396 bb 4x4 project 1982 K5 Blazer Silverado 4x4 519,348 miles |
Re: 5.3L cam swap
Install new springs!! The stock springs become weak, Seen too many LS engines break springs at 150,000 to 200,000 miles.
GM ZO6 springs for $4 a piece ![]() |
Re: 5.3L cam swap
Is there a specific spring I should use or can I use new stock 5.3 springs? What about the pushrods? Aside from maybe replacing them can I use the stock ones?
Re: 5.3L cam swap
The LS6/LS2 springs in the link work perfect, Below 6,000 the stock push rods are fine, Beyond that...Hardened push rods are a good idea.
Fabricate till you "puke"
Re: 5.3L cam swap
Agree with the springs/pushrods....but have to ask? Will that 6 .0 truck cam show you any more than what you are running? From the read that I have done, it sounds like the truck cams are pretty much the same grind, as well as the LS-1 cam? I opted for the Ls2-6 springs on my stock 5.3 , when the valves were ground & ran the stock pushrods(no plans to spin it over 55-5700, from time to time). If I am off on the cam specs, I am sure somebody will post the info, to help you....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Re: 5.3L cam swap
Well, I am not 100% sure but my stock 5.3L only pushes out 285hp and the cam I have is for the 345hp 6.0L so I would believe that the cam specs are quite a bit different. I will look for the specs and post them soon.
Re: 5.3L cam swap
This is what I have found so far. I need to verify that my cam is actually these specs but the 5.3 and 6.0 cams are different. If this is the case I am not sure for the small difference ibetween the cams I want to go through with the swap now. Maybe I should just get a custom tune done and call it a day.
6.0 LQ9 207/196 int/exh @ 0.05" duration 0.479" / 0.467" int/exh lift 116 LSA 5.3 LM7 190/191 int/exh @ 0.05" duration 0.466" / 0.457" int/exh lift 114 LSA
Re: 5.3L cam swap
that cam swap wont be noticable. find a used ls6 cam or go custom grind. look into the vinci trucker cam.
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana ![]() instagram - @esso_c10 @projectpawpaw |
Re: 5.3L cam swap
Honestly it seems the production cams are not a big enough difference to make the swap worthwhile. There are plenty of companies like Comp and Texas Speed that will have more of what you'd want. And yes, the truck cams are pretty much the same, but they got just a hair bigger in the later years. As mentioned above, it's not a good idea to run any larger than a stock cam with the stock springs. Also another thing to consider, with a big enough cam the base circles are usually a little smaller, sometimes requiring long pushrods. A simple cam swap can easily run up into the $1000 range (assuming you buy new).
Not trying to burst your bubble, but a cam swap is a lot of work (and money) and I'd hate to see you go through that and not have a noticeable difference.
71 K20 64 GMC mud truck |
![]() Join Date: May 2011
Re: 5.3L cam swap
Ls6 cam!
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
#11 | |
Re: 5.3L cam swap
Re: 5.3L cam swap
The parts sure are not cheap (new)! I added the LS6 springs , when my heads were done....probably opt for a used Ls6 camshaft, when the time comes? Thanks for the info that you posted
