05-06-2014, 02:29 PM | #1 |
Bleeding the Power Steering
I have air in the PS can't seem to get it bled. I have raised the front wheels and turned the wheels from side to side (EO) at least 15-20 times on 2 occasions. I'm getting the grinding sound like the fluid is low (intermittent) and once I shut the truck off it will push the PS fluid out of the reservoir. Tried everything I know, any suggestions? Thinking I may need to replace the PS pump...
It's a 1962 C-10 383 Stroker, think it was fitted with the pump and gear from a 1968-1972. Thanks for your thoughts, |
05-06-2014, 03:08 PM | #2 |
Re: Bleeding the Power Steering
I had the same problem I replaced the pump and problem solved. Once the pump was installed I turned one way and on the way the other way it started working with no problem
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
05-06-2014, 03:14 PM | #3 |
That's what I figure will be my next step. Just wanted to get some other thoughts just in case I'm missing something.
Thanks, |
05-06-2014, 11:45 PM | #4 |
you can rebuild these pumps for under $20 and it's real simple. There are several videos on youtube with step by step instructions. I just finished doing mine.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
05-07-2014, 07:48 AM | #5 |
pdxhall,
Thanks I will look into rebuilding it. |
05-14-2014, 01:33 PM | #6 |
Replaced the pump, seems to have taken care of the air issue...
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400 1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver John 3:16 |
