06-17-2014, 11:58 AM | #1 |
71 SPID Decode Needed
I am painting the front of my glovebox and figured this would be a good time to decode the SPID. I know that there are several members on here are great for this info. Sorry for the poor pics.
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
06-17-2014, 03:16 PM | #2 |
Re: 71 SPID Decode Needed
Here's a close-up picture of it: . . . . |
06-17-2014, 04:41 PM | #3 |
Are all the 67-72 guru's on vacation? You gonna make the squarebody guy do this?
Well - off the top of my head, here's what I see: B93 - Door edge guards DG4 - Exterior mirrors below eyeline stainless G50 - HD rear springs PV6 - Tires H78-15 belted white strip U63 - AM radio Z53 - gages (amp, temp, oil, etc) __5 - Dark Green (exterior color) A11 - soft ray tint - all windows G80 - limited slip/locking rear (non-open) F59 - Front stablilizer bar F60 - Front spring capacity P01 - wheel covers V46? maybe? - chrome front bumper Z84 -Cheyenne trim level 62I -interior color and trim
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-17-2014 at 04:54 PM. |
06-17-2014, 04:42 PM | #4 |
...and here is the link if you would like to see for yourself.
K http://www.gmheritagecenter.com/docs...olet-Truck.pdf
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-17-2014, 05:06 PM | #5 |
CE141F_ _ 8474 Conventional Cab, 1/2 ton pickup, 1971, Flint assembly plant, _ _8474 unit serial number
127 (Wheelbase) MODEL= CE10934 (Conventional, V-8, Fleetside, LWB, 307/3-speed/3.73) 1B93AA DOOR EDGE GUARDS 1DG4AA BELOW-EYELINE MIRRO (tripod leg mirrors) 1G50AC HEAVY REAR SPRING (2000lb ea) 1PV6AB H78X15 BELTED WHITE (five highway white walls) 1U63AE AM PUSHBUTTON RADIO (AM radio with push buttons) 1Z53AQ AMMETER,OIL-TEMP GA (gauges no tach) 1505AA DARK GREEN (non-metallic solid paint) 1A11AA TINTED GLASS 1C80AA DOME LAMP SWITCH (door operated dome lamp) 1F59AA FRONT STABILIZER 1G60AN AUXILIARY SPRING (500lb ea leaf helper spring) 1P01AA FULL WHEEL COVERS (full wheel cover option vs a standard hub cap) 1V43AD REAR STEP BUMPER 1Z84HA CUSTOM SPORT TRUCK (Cheyenne trim and emblems) 1621AA SADDLE VINYL CUSTOM (trim color and type callout)
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-17-2014, 05:20 PM | #6 |
That's good to know. It looks like my truck has been changed even more than I had thought. It currently has a 350 and an open 3.08 (according to the gear caluator) coil spring rear.
06-17-2014, 05:58 PM | #7 | |
The engine might be a 307 under a 4 bbl intake. If you are not sure check the casting number, date and engine assembly numbers. The rear gears could have been changed anywhere along the line even at the dealership. Check you axle codes if you really want to know more. You truck (as built) had the default coil spring rear suspension. In addition it had the HD coil and the helper leaf spring options that contacted the trailing arms behind the axle.
06-17-2014, 07:11 PM | #8 |
Thanks for the info I found the engine code from the block. It says:
V0825DMB 199403799 It looks like its a later engine.
06-17-2014, 09:20 PM | #9 | |
Mind you later numbers are not my strong point but I try to have a good database for such an issue. So... That 199403799 looks like a VIN code, was it stamped near to the engine assembly code? If so it appears to be for a '79 Oshawa built vehicle with a 267! The DMB suffix code comes back as a 79 L-39 267 or an 81 LM-1 350. Time to check the casting numbers, in fact all the numbers carefully.
06-17-2014, 09:30 PM | #10 |
The VIN code was stamp directly under the engine assembly code. It pulls like a 350 which is what the POs claimed it was. It also has 3998991 heads which according to my book is possibly the original 1971 heads. I am starting to think that this engine was pieced together at some point.
