06-22-2014, 03:38 PM | #1 |
alternator. keeps puking
I updated my electrical with a serpentine setup from a 1991 suburban and I keep burning alternators. The 1972 blazer has a 2 wire system and the 1991 alternator has 3 wires and I have been just leaving one wire blocked off. Charges perfect but keeps burning alternators. Anyone been through this before?
1972 Blazer - Bronco Orange - In the werks http://67-72chevytrucks.com/vboard/s...d.php?t=323444 1991 F250 - Hunting truck w/ Detroit rear locker, ARB front locker, front and rear winches .... and more.... 1997 Grand Cherokee - fun jeep - Detroit rear locker, ARB front locker, front winch, 411 gears, lots of lights ;-) 2004 Hot Rod DuraMax - Dnyo'd at the wheels with 525 HP and 1100 lbs torque.....mustang killer. |
06-22-2014, 06:07 PM | #2 |
Re: alternator. keeps puking
where are you geting teh alt from? i had an issue with advance auto where i got 5 yes 5 bad alts, but from the sound of it it is not wired right and in full 100 percent charge mode
06-22-2014, 06:15 PM | #3 |
l;ook here is a wiring diagram for the cs style alterantor you have its the bottom one on teh post
06-23-2014, 12:47 AM | #4 |
I'll check the link, thanks. I use NAPA Gold alternators......its gotta be something else
06-23-2014, 09:10 AM | #5 |
Hollister Road Co.
connect the third wire or convert to a single wire. Sounds like you have capped off the sensing wire and the ALT doesn't know when to shut down.
06-23-2014, 09:20 AM | #6 |
Msgt USAF Ret
I went through your build thread and didn't see how you wired the alternator. Could you show how you wired it and did you install the extra resistor in the wire that goes to the L pin in the alternator? The alternator will charge without the resistor but it won't last very long.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
06-23-2014, 09:44 AM | #7 |
I seem to remember reading somewhere there is a difference in the alternators when GM went to the serpentine setup - external regulator vs. internal regulator. I have seen a wire pig tail adapter to make the swap on Summit Racing's site.
06-23-2014, 09:50 AM | #8 | |
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
06-23-2014, 12:29 PM | #9 |
VetteVet seems to have the answer I'm looking for. I'll give that a try. Thanks for the help!
07-06-2014, 12:02 PM | #10 |
DID this get fixed?
07-06-2014, 07:06 PM | #11 |
If you look at the GM assembly manual for factory equipped internally regulated alternators on vehicles with stock gauges and not lights, the length of the stainless resistance (sensing) wire is approx. 10 ohms similar to what GM did with pre-HEI externally mounted coils. If you opt not to use this wire, you must use a 10 ohm resistor inline or a blocking diode works as well but a resistor is just as good. If unsure, install a resistor anyway for safe measure.
07-06-2014, 08:57 PM | #12 |
Msgt USAF Ret
That's fine for the 10 and 12 SI alternators but the CS and later styles require a larger ohm resistor. Painless recommends an 85 ohm 5 watt and others have used 1 watt and 300 ohm resistors. I wouldn't put a 300 ohm in because it might restrict the trigger voltage too much. I have read that 35 ohm is the minimum so I'd go with the near 100 ohm depending on what I could find.
