11-25-2014, 08:34 PM | #1 |
headlights not working
Hey guys, went out this morning and headlights would not turn on. All marker and brake lights work. The dome light works when tried also. Could this be a switch if all other lights work? Just happened out of nowhere. My headlights also have aftermarket relays. Thanks in advance.
11-25-2014, 08:49 PM | #2 |
Re: headlights not working
check the dimmer switch and see if there is power there
11-26-2014, 01:12 AM | #3 |
no idea what year truck you have...
read this thread it has a lot of info on the headlight circuit tail, brake, marker and dome lights have little in common other than the switch, different circuits all together do your instrument panel lights work? though i suspect your headlight relays are the culprit and since it's custom no one can throw a wiring diagram up and say ''here'' i am not a fan of relays in the low beam headlight circuit, it adds multiple failure points in a critical circuit high beams circuit? ok. you can always switch to low beams if you own and can use a multimeter, start chasing the power and read my signature line, the lower one that says... how to put your truck year and build thread into your signature
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-26-2014, 10:29 AM | #4 |
Its a 70 c10. All dash lights work, dome, marker, tail, etc. Just no headlights. Ill check the dimmer switch and start chasing power.
11-26-2014, 12:40 PM | #5 |
I unplugged the wires from the relays and connected them. I checked the male/female connections to the original wiring to the relay wiring. I'm not sure the issue but I pulled the headlight switch and the lights came on. Could there be an issue or any way to test the mounted relays themselves? They are the black relays that come with the LMC kit.
11-26-2014, 03:16 PM | #6 |
Msgt USAF Ret
You can test the relays easily without using the headlight switch or the dimmer switch.
You will have to determine whether the 85 terminals are the grounds for the relays or if the 86 terminals are used as the grounds as in this diagram. You also need to make sure that the grounds are good. Once you have done that, just jump between the no. 30 terminal and the 85 or 86 whichever is grounded and the relay should close and the headlights should come on for low or high beams depending on which relay you are jumping. If the relay doesn't close, check for power on the red wire from the battery. If the relay closes with the jumper but not with the dimmer switch, then check the green or tan wire connections at the dimmer switch and at the relays.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-27-2014, 11:47 PM | #7 | |
as vetvette mentioned, check power at the red wire if you have a fuse where he has fuse/breaker indicated; it should be an auto reset breaker for this exact reason you do not want a headlight fuse popping, an auto reset breaker will flash and allow you to safely pull over
11-28-2014, 12:54 AM | #8 | |
Msgt USAF Ret
Yes you are absolutely right. Thanks for the correction I was getting ready to leave for that big turkey dinner and in a bit of a hurry. I try not to make goof-ups like that but I'm sure glad you guys keep me straight.
