05-10-2016, 08:50 PM | #1 |
Loud rapid rattle from PCV, while running.
I'm getting a loud rattle at idle and even louder during part throttle. I replaced the PCV and am still getting the noise. The new one looks different from the one that was there. It's so loud I can here it from the cab, while driving. The parts store looked it up and ordered it, so it's supposedly the correct part.
Has anyone experienced this? Is it an indication that I have the wrong part? Posted via Mobile Device |
05-10-2016, 08:58 PM | #2 |
Re: Loud rapid rattle from PCV, while running.
Are you sure it's the pcv?
Pull the hose off the carb and plug it to test. What do you have for air inlet on the other valve cover? |
05-10-2016, 09:17 PM | #3 | |
05-10-2016, 09:57 PM | #4 |
Do you have a good solid vac hose. When they get older they collapse easily.
05-10-2016, 10:18 PM | #5 | |
05-10-2016, 11:55 PM | #6 |
*** That's interesting ***
Next step after that is to pull the pcv valve again and stick your finger over the valve cover hole. If you can feel pulsing pressure, you may have a cylinder that lost a ring and causing lots of blowby. Let's hope not.
Compression and leakdown test would be next if you suspect that.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
05-11-2016, 07:12 AM | #7 |
Do you have a aftermarket cam in the engine . An aftermarket cam can cause low vacuum in the intake and pulse the pcv ( seen this many times ) . If it is a stock cam you most likely have a burned intake valve allowing the cylinder pressure to push back into the intake and pulse the pcv . You can hook up a air hose the spark plug hose to see if one of the cylinders is pushing air into the intake .
05-11-2016, 07:25 AM | #8 | |
05-11-2016, 08:16 AM | #9 |
The pcv will pull at idle . The spring valve reduces the volume when it closes at idle and low rpm, other wise it would be a big vacuum leak . 20in of vacuum is pretty strong . Just by putting your finger over the end will feel like a lot . That normal .
With a stock cam at this point I would suspect a burned valve or sticking valve pulsing back into the intake and allowing the pcv valve to pulse when the cylinder pressure enters the intake . Note , The pcv valve never closes it only restricts |
