Old 01-27-2017, 01:46 AM   #1
master 1969 c10
Active Member
Proportioning valve question
I bought this kind of a set up from vender pickmup and on the proportioning valve is only one line hook up what do I need to do
master 1969 c10 is offline   Reply With Quote
Old 01-27-2017, 10:19 AM   #2
dfwright
dfwright's Avatar
Re: Proportioning valve question
There must be at least two outputs. One for the front brakes and one for the rear, otherwise there's no "proportioning" to be done. I know some prop valves have two outputs to the front, one for each side, but the factory configuration on the 72, at least, was to have one output to the front, which went down to a "T" splitter at the crossmember, and then out to each front wheel from there.
The front output is usually on the bottom of the prop valve toward the front.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 01-27-2017, 06:07 PM   #3
donandal
you should have three...
53 Chevy Pickup
donandal is offline   Reply With Quote
Old 03-06-2017, 01:41 AM   #4
Smokeem
Where can you get a plug to cp one of the two outlets for the front brakes?
Thanks Rick
Smokeem is offline   Reply With Quote
Old 03-06-2017, 10:16 AM   #5
dfwright
dfwright's Avatar
Any decent auto parts store should sell the plugs. I got one at Autozone.
