09-25-2017, 11:54 PM | #1 |
Edelbrock Carb + Intake Found
We were cutting converters to send out cars for scrap and found an Edelbrock Carb + Edelbrock intake sitting on top of a swapped out 350 that looks like it blew a head gasket. Went ahead and removed it. Would it be worth swapping out the Qudrajet with this? Just the carb or do both?
Edelbrock 1406 Carb attached to a Edelbrock Performer RPM Intake
2002 Mustang GT Convertible (Mineral Grey) 2003 Mustang GT Convertible (Triple Black - wife D/D) 2013 Ford F550 XLT (Tow Truck - my D/D) 2006 Kawasaki Vulcan 750 1984 C10 Custom Deluxe |
09-26-2017, 07:59 AM | #2 |
Re: Edelbrock Carb + Intake Found
If q jet is working fine and has no problems, don't mess with. Keep the Edlebrock on the shelf if the q jet ever does start acting up.
1980 Silverado short bed 1993 GMC 1500 LS swap 2006 Lifted Z71 Crew Cab |
09-26-2017, 09:23 AM | #3 |
It should be an easy $100 bill on craigslist, probably more if it was cleaned up.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
09-26-2017, 12:32 PM | #4 |
Looks new, my only current concern with qjet is electric choke plug is broken
09-26-2017, 03:50 PM | #5 | |
https://quadrajetparts.com/electric-...ster-p-72.html |
09-28-2017, 12:35 AM | #6 |
Sell the carb keep the intake or use it.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
