Old 11-04-2018, 02:54 AM   #1
caspear1978
Broke fuel tank strap. Now odd issues
A couple of weeks ago my front strap broke on my fuel tank. Replaced the strap no issues with install.
Now my fuel gauge wont read right. One minute it reads full. One minute it reads empty. And if i do get it to read correct. It'll move up towards full instead of moving towards empty.
Then today it started running sluggish. No power when on the throttle. Pulled codes and other then the normal 02 sensor codes. I pulled a number 2 misfire code.
Shut the truck down for about 10 minutes and took the truck to town. Ran great for about 4 miles. Then acted up again. Get to town put some fuel in and a bottle of injector cleaner in. After leaving the gas station truck ran fine till about a mile from the house. Acted up again. Let it sit for about 30 minutes. take it for another drive to show a friend what its doing. Run an easy 20 miles no issue.
one thing i did notice before the last run was that it seemed to act up when it reached operating temp. my friend hooked up a scanner that can show real time readings from the truck. I wanted to watch the coolant temp. to see if it showed an issue once it acted up. Stayed steady at 190.4 no issues.
I'm truly stumped with this issue. Not really sure where to begin looking.
caspear1978 is offline   Reply With Quote
Old 11-04-2018, 09:35 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: Broke fuel tank strap. Now odd issues
EDIT *** See my next post. This one was incorrect because it was based on prior experience with older rigs...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-04-2018, 10:19 AM   #3
hatzie
Moderator
hatzie's Avatar
I dug into the 05 service manuals.... hopefully your vehicle model year isn't too much different. Since you neglected to tell us that important piece of information I don't know.
In the 2005 GMT800 trucks...
The fuel gauge is a loop from the PCM through the sender rheostat. The PCM then provides Class II serial data to the instrument cluster... The fuel gauge doesn't rely on a frame ground.
The fuel pump does rely on a frame ground.
Nearby grounds are as follows...
The G401 ground is on top of the flat plate on top of the round crossmember behind the rear axle on my 2005. This may be the rear lamps or it may be the fuel system.
The G302 ground is on top of the over-tank crossmember mounting bolt above the LH frame rail on the HD & 2500,3500 models and on the 1500 it's on the forward cab mount off the frame.
The G110 ground is on the forward cab mount off the frame.
A sharp jerk on the Metripak connector at the fuel pump, from the fuel tank sharply dropping further than the slack in the harness, might've damaged the fuel sender/pump wires, terminals, or connector.
You aren't showing a P0442 or another evap code so the tank pressure sensor, which is a separate connector, is probably still making good contact in its' loop from the PCM.
My guess is you damaged the Metripack 150 connector to the fuel pump. The easiest way to deal with it on a GMT800 is to pull the bed and take a look. DO NOT USE AN IMPACT GUN ON THE BED BOLTS. You'll spin the nuts in the sheet metal housings with an impact.
