Closed Thread
Old 06-21-2019, 10:37 PM   #1
Softpatch
Softpatch's Avatar
Just when you think your out (64 Fleetside)
I just picked this 1964 Fleetside custom
No running gear was an Auto Non PS/PB
I'm going to merge this very rusty (Michigan) 02 silverado
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline
Old 06-21-2019, 11:47 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Just when you think your out (64 Fleetside)
Are you saying you're going to put it on the silverado frame?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline
Old 06-22-2019, 12:59 AM   #3
Softpatch
Softpatch's Avatar
Yes.?
Old 06-22-2019, 08:25 AM   #4
spudder
Active Member
I think I would try to keep the original frame. The frames on the '99-'07 trucks are very bad about rusting through.
If you are set on using the '02 frame, make sure it doesn't have serious rust issues in the boxed areas.
spudder is online now
Old 06-22-2019, 08:56 AM   #5
Clyde65
Clyde65's Avatar
Stance on the newer is 6” wider than the 60-66
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 06-22-2019, 11:42 AM   #6
LostMy65
LostMy65's Avatar
LostMy65 is offline
Old 06-22-2019, 11:06 PM   #7
Captainfab
60-66 Nut
The '88 and up frames are drastically different from the '63-'87 frames. You are in for a LOT of fabricating and work.
Captainfab is offline
Old 06-23-2019, 12:54 PM   #8
LostMy65
LostMy65's Avatar
Btw... The fender emblems are from a 66.
LostMy65 is offline
Old 06-23-2019, 03:26 PM   #9
66x3
Very rusty?!?! Man if you were from Michigan that would be considered a pretty darn clean truck! No rust on the box,rockers still on, that thing must have migrated your way a long time ago.
66x3 is offline
Old 06-23-2019, 03:27 PM   #10
66x3
Cab corners too!
66x3 is offline
Old 06-23-2019, 11:26 PM   #11
Softpatch
Softpatch's Avatar
Thank you for that ....
The dash cluster should have been a give a way.
you are correct it is indeed a 1966 not a 1964.
and thanks for the heads up on the wider frame on the 02
.....W
Old 06-24-2019, 03:55 PM   #12
LostMy65
LostMy65's Avatar
Personally, I think the 66 is best of the generation.
If you decide to skip the frame swap idea, are wanting to stay with the 3/4 ton, or were you thinking of converting it to a 1/2 ton?
LostMy65 is offline
Old 06-25-2019, 12:11 AM   #13
Softpatch
Softpatch's Avatar
I don't have a clue.?
I have a problem I like to rescue cars/Trucks that have been passed on.
The 02 silverado 1500 was a $200 truck its is rusty it has a 4.3 and a 4L60E
Trans need love
it's to light for what a need..
the 66 custom was rusting in a yard under a pine tree the owner just wanted the Drive trane 454/T400
then back out under the tree..... I had to save it
not my favrote yr I'm a knee knocker guy
My old truck
Old 06-25-2019, 10:10 PM   #14
sprinter11r
sprinter11r's Avatar
once you are in, you are never out..... even if you think you are...lol
sprinter11r is offline
Old 07-02-2019, 11:19 PM   #15
Softpatch
Softpatch's Avatar
Continued
http://67-72chevytrucks.com/vboard/n...=newthread&f=6
Old 07-03-2019, 10:32 AM   #16
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Closing this thread as OP started a new thread instead of updating this one.
Part II found at http://67-72chevytrucks.com/vboard/s...d.php?t=789617
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Closed Thread
