Old 08-08-2019, 11:14 AM   #1
DawnK31
69 C10 Wiring (69 corvette 350 small block)
I am replacing the engine in my 69 c10 with a 69 corvette 350 small block. I am having trouble finding the wiring diagram.
Can anyone point me in the right direction?
DawnK31 is offline   Reply With Quote
Old 08-08-2019, 03:02 PM   #2
demian5
demian5's Avatar
Re: 69 C10 Wiring (69 corvette 350 small block)
Its the same. Same wires go to the same things. The things may just be in a different place.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-08-2019, 03:05 PM   #3
MJN
MJN's Avatar
What engine are you replacing? Inline 6? Small block or big block V-8? Was it the original engine that you are pulling out? Are you changing from points to HEI or had it been converted already?
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 08-08-2019, 03:34 PM   #4
DawnK31
We replaced with a small block 350.
Old 08-08-2019, 03:38 PM   #5
MJN
MJN's Avatar
Yes- I got that you installed a small block from your initial post. What was the original engine that you replaced? That will determine which wiring your truck has and how the wires are routed or were routed.
'17 GMC Yukon XL
VCCA member #58596
Old 08-08-2019, 04:15 PM   #6
DawnK31
When I bought the truck I was told it was an original engine but when it started coming out it look like it was a mismatch of different part. But I have to assume for sake of argument it was the original engine
QUOTE=MJN;8572921]Yes- I got that you installed a small block from your initial post. What was the original engine that you replaced? That will determine which wiring your truck has and how the wires are routed or were routed.[/QUOTE]
Old 08-08-2019, 04:23 PM   #7
geezer#99
geezer#99's Avatar
Was it a six cylinder or a v8?
We need to know that.
Old 08-08-2019, 05:07 PM   #8
demian5
demian5's Avatar
I-6 or V8, its the same. Same wires go to the same things. The things may just be in a different place.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 08-08-2019, 05:11 PM   #9
DawnK31
v8
Old 08-08-2019, 07:42 PM   #10
demian5
demian5's Avatar
1986 C20 Scottsdale
Instagram: C10sofOC
Old 08-08-2019, 08:24 PM   #11
geezer#99
geezer#99's Avatar
v8
Now we know you’re replacing a small block, it would be nice to know what wiring you have now.
You should have two to the starter, one for the temp sensor, possibly two to the coil and possibly one to the oil pressure switch.
Do you want instructions where they go or do you prefer a complicated underhood wiring diagram and then figure it out from there.
Pics help a bunch.
c10, corvette, engine, wiring
