Front crossmember swap?
I have a 1966 gmc 1/2 ton pickup and I am looking for the easiest cost effective way to get disc brakes and power steering. I have heard you can you the front crossmember from a 73-87 pickup, are Van's also the same? And input is much appreciated! Also looking to fit a 454 in but that may be a whole other can of worms!
One foot in front of the other
![]() Join Date: Aug 2008
Re: Front crossmember swap?
FAQ section has all kinds of good info.
Im pretty sure 72 and up cross member is a direct bolt on , I plan to do one in the near future on my 65 shorty Bellsouth truck . The power steering is a little more involved but doable .
'84 'Burb crossmember fit my '61, but I had to drill some holes. And if I'm going to drill holes, I might as well move the crossmember forward 1". Which I did.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate Last edited by SkinnyG; 01-27-2020 at 01:22 AM. |
![]() Join Date: Sep 2006
You can bolt on later model control arms on the 63 and up trucks. You do not have to swap out the cross member.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
I just completed a swap like this. I have a 63 C10 that I stuck a 78 C10 front crossmember in. Real easy swap, everything but 1 bolt hole on both sides of the frame matched up.
63 C10 |
Vans are NOT the same. They have a wider stance both front and rear.
![]() Join Date: Aug 2004
73-87 c10, Suburban will work great!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Ok thank you guys for the very useful information I really appreciate it! So Van's wont work but suburbans will? How bout would blazers or Jimmy's?
60-66 Nut
Any 1/2 ton 2wd truck based front suspension will work. So yes a 2wd Blazer or Jimmy will work. Regarding the full size vans, the spindle, rotors and calipers will work on your original control arms with a ball joint swap. The van control arms are basically the same as the C10 truck control arms, but the shafts are weird, with a tube on the outside with rubber in between. At least the set I have from a '85 G10 van are. The van steering box will not work as they are backwards from a truck box even though they look the same.
Installing a big block is not that difficult. I've done it about 28 years ago and many, many others have as well. I do make the steering box adapter plates as well and many other products.
