11-21-2022, 09:26 PM | #1 |
Class 4 Trailer Hitch
I found some others using a Curt 14082 trailer hitch. That hitch setup seems like it could be a little wider but I can make it work, I read the holes are 31 1/4" between centers. If I use that hitch ill be reinforcing the rear of the frame since it just bolts to the lower flange.
I want a class 4 so any lesser ratings are off the table. What hitch are you running and did you stiffen the frame? Pics? Im planning on putting a fuel tank back there so trying to make compatible decisions and get both of these items ordered.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations Last edited by May70; 11-21-2022 at 09:53 PM. |
11-21-2022, 11:14 PM | #2 |
Re: Class 4 Trailer Hitch
This is an Old thread so here is an idea.
#29 and #42 Link: https://67-72chevytrucks.com/vboard/...r+hitch&page=2
11-22-2022, 01:59 AM | #3 |
70+ ( Old Skool Club )
Early Classic Enterprises Stainless Steel Tank I bought in 2003 and the Hidden Hitch they sold and both installed last year in 2021.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-22-2022, 01:09 PM | #4 |
Nice install! I think I am also going to do a hidden hitch as well.
11-22-2022, 05:32 PM | #5 |
Had one made for my truck by a local fabricator and good friend . Truck already had massive brackets for the step bumper made out of 1/4 inch plate we just added to it .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 11-22-2022 at 05:51 PM. |
11-22-2022, 06:28 PM | #6 |
I installed a 37042 Reese multi fit class III hitch in my 69 C-10. I moved my gas tank lcation to the rear so the crossmember you had to remove for the gas tank to go in I welded it to the very rear of the frame so the last crossmember is still there. I used 1/4" plates and drilled them for the hitch to bolt to them and the frame rails. This kept the hitch in the same postition as it was when it bolted directly to the frame.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
