11-05-2022, 07:03 PM | #1 |
95 Cadillac Northstar 4.6 Engine
are these engines any good and how big of a pain would it be to put one in my 68 chevy short bed? I can pick it up the car for $150 to $300 depending on how much I need to do to it I know I will need to replace all of the gaskets and timming chains at least, mostly for my pice of mind. The car has about 120,000 on it
11-05-2022, 07:41 PM | #2 |
Re: 95 Cadillac Northstar 4.6 Engine
The early north stars had issues with the headbolts pulling out. They have kits to repair that but I think it takes some specialized tools. The starter is under the intake valley. I believe the oil pan is two piece. They are prone to leaking in the earlier years like that.
Later on they had most of that sorted out I’m not sure I would touch a 95 in a Cadillac let alone use it for a swap engine. I am also interested to hearing other replies.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
11-05-2022, 07:45 PM | #3 |
I remember hearing about a lot of issues with those North star engines back then, I would Just google it I am sure you will find your answer
11-05-2022, 08:03 PM | #4 |
I knew about the oil Pan leaking and figured that there was an upgraded gasket set by now to fix that problem I also know that it is an all aluminum block but I had no idea that there was a problem with the headbolts pulling out of the block or where they put the starter
11-06-2022, 01:29 PM | #5 |
I know for sure that when one of these came into the shop NOBODY wanted to put their name on the work order. Even my friends at the dealer tried to avoid them. They had all kinds of problems
11-06-2022, 01:54 PM | #6 |
I believe this should be on the required reading list. Especially paragraph 4.
https://en.m.wikipedia.org/wiki/Northstar_engine_series
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-06-2022, 03:16 PM | #7 |
Nothing wrong with the 2005 and later engines.
11-06-2022, 06:40 PM | #8 |
Except for the low price, you don't gain anything with this engine. I'd keep looking.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
11-07-2022, 08:37 AM | #9 |
All that complexity for only 300hp? I would find an LS1 engine which can be had for probably a few bucks more and you will match that. Add a cam and headers and you are probably 50hp above and parts are everywhere.
11-07-2022, 11:33 AM | #10 |
I'll add.... w/far more support & less complexity.
11-07-2022, 01:33 PM | #11 |
Ya but the starter is inside the oilpan and I herd the carburetors are upside down on LS1's making it hard to refill the blinker fluid.
In all seriousness an engine as nutz as the northstar would be a very odd swap, going to way too much trouble. If you ever sold the truck, there wouldn't be a single person that'd be happy to find out it had a northstar in it. |
11-07-2022, 02:07 PM | #12 |
Agree-a base 5.3 truck engine is more than 300 HP and a whole lot easier to swap in and more support, not a strange transmission bolt pattern, etc. Unless you have a real desire to do a Northstar swap, I would not do it.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
11-09-2022, 10:44 PM | #13 |
I agree with all above but a 2.8 -3,1 s10 or Camaro engine has the same trans pattern for what that is worth. I got one in a BUICK Lucy I junked out had it a while zero calls for it
11-10-2022, 01:53 PM | #14 |
case half seals are prone to leaking and you have to split the engine to replace it. also had overheating issues
1967custom |
11-10-2022, 03:53 PM | #15 |
For a legacy corporation GM has made some incredible vehicles but also some atrocious ones. The Vega and the Northstar engine are sadly linked together in one major area. The cylinder walls in each deployed significant changes in design from standard practice. Take a moment and learn what led to the demise of both, due to to far ahead thinking.
71 C-20 07 Magnum RT AWD |
11-10-2022, 06:05 PM | #16 |
Is this a truck you may want to drive someday?
I got a bench seat baby, you don't have to sit over there. |
11-19-2022, 04:43 PM | #17 |
I do plan on driving my truck it will not be my daily driver, but she will see the highway during the summer months. To be honest I forgot about the tranny bolt pattern and the amount of pain and suffering I will have with that and that is why I don’t want to use the 455 rocket Oldsmobile motor I have I will save that one for something else. I do want to keep the manual transmission in the 68. I think I’m going to rebuild the 307 that is in it now the compression is good, but it does need some gaskets a timing set and a carb. I think I will spend the money I would put in the motor swap into the body and the rest of the running gear
