Old 03-24-2006, 08:15 PM   #1
Solver
Solver's Avatar
Need rear axle enlightenment
Was checking codes in a glove box on a 67 1/2 ton and found one with a listing of JO4aa SP44 G87 power lock with 3.54 gears.Then it specifically listed apart number of 3903545. So I am assumming it was some kind of special order rear end. I understand the positraction but what is the differences between that and NO-spin and Power Lock ---codes below
G80-Positraction
G86-No spin
G87-Power Lock
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 03-24-2006, 08:18 PM   #2
1969k10stepside
Re: Need rear axle enlightenment
A question for longhorn man.
1969k10stepside is offline   Reply With Quote
Old 03-24-2006, 08:55 PM   #3
1969 GMC
1969 GMC's Avatar
it's a dana 44, the power-lock was only for spicer axles. i have seen a few other 67 (and earlier) 1/2 tons with a d44 rear. usually gmc's.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 03-24-2006, 11:15 PM   #4
Chris H
72 C30 Trailer Queen
Chris H's Avatar
I agree. Its a Dana 44 (the sp44 stands for spicer 44).
3.54 with powerlok, a clutch type posi unit for dana/spicer rears.
I have a 68 GMC C15 with a 396/TH400/dana44 3.54 (build sheet verified).
It could use a posi rear (hint, hint!).
I will go out on a limb here and guess that you could only get a Dana 44 rear in leaf spring configuration? Anyone have any evidence of a D44 coil rear?
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 03-25-2006, 06:19 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
longhorn man knows nothing about this... and, that 3.54 gearing is a totally new one my me.
Old 04-06-2021, 06:35 PM   #6
countr
countr's Avatar
Found this old post and could not find any other on the subject. But the 67 GMC I am working on has the sp44 3.54 ratio but has J04AB on the spid and part number 3903540 with a 305 v6. Just wondering would this be posi[traction or no spin and what is the difference?
Thanks Russ
countr is offline   Reply With Quote
Old 04-06-2021, 07:31 PM   #7
HO455
HO455's Avatar
The different names are a result of the branding by the different manufacturers for a clutch style limited slip differential (LSD). So a Power lock and a Positraction LSD are both the same thing but for different axle brands. And adding to the confusion a Dana 44 in a GMC had a Power Lock but a Dana 44 in Chrysler had a Sure Grip.
Even among the various GM brands there were different names for the same limited slip units. Pontiac called theirs Safety-T-Trac, where Chevrolet called it Positraction, and Oldsmobile named theirs Anti Spin.
Then throw in 10 bolts that have cone style LSD and 12 bolts that are a clutch style, and depending on which piece of factory literature you refer to both styles may or may not have the same name. No wonder it can be confusing.
And all that was before the aftermarket got involved. Whew!
The link has more information.
https://en.m.wikipedia.org/wiki/Limi...p_differential
RIP Bob Parks.
Old 04-06-2021, 07:54 PM   #8
countr
countr's Avatar
Thanks for the clarification, very good information.
Thanks Russ
Old 04-06-2021, 08:51 PM   #9
Mike C
Mike C's Avatar
I'm going to split hairs a little with the Positraction being the same as the PowerLock. Yes, they are both clutch type limited slips. The Dana diff is a 2 piece case that has "ramps" in the case that increases the preload on the side plates with power application. Probably the best clutch type LSD ever.
3.54 gears a very common ratio in Dana axles. Was the stock ratio in big block powered trucks with Dana 60 rear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-07-2021, 01:35 AM   #10
kwmech
I always thought the no-spin was a detroit and the others were either a power-loc or an eaton
