04-30-2022, 10:19 AM | #1 |
65 GMC Suburban
I’m in a place I can’t work on my toys, so gotta let this one go.
1965 GMC suburban, I have all three seat frames for the GMC( different than Chevy) I have already done the front disc conversion, brake booster/master, power steering, steering column rebuilt for a floor shift. I have all Steele Rubber seals for it, 3” drop rear leafs, EFI fuel tank, Trans crossmember, motor mounts. This has the two slider windows on each side. There is a little rust above the windshield but imo, very fixable, both fenders have rust, drivers toe board(small) and outside lower doors, I have most of the patch panels too. Like everyone else, I have more in it than I’m asking, $8500 price drop, sold motor/trans. I can’t upload multiple pix so, I’ll send some more if you will give me an email.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 05-03-2022 at 08:45 PM. Reason: Sold motor/trans-price drop |
04-30-2022, 12:33 PM | #2 |
Re: 65 GMC Suburban
On the pictures, try hitting the upload button 5 times per post. Hit the upload button with each picture you choose. If you try to upload all 5 pictures with one click of the upload button, you get a security token issue, right?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-30-2022, 01:38 PM | #3 |
Re: 65 GMC Suburban
Yep, that’s what I get. I’ll try that, thanks!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-01-2022, 03:15 PM | #4 |
Re: 65 GMC Suburban
Happy to help!
