08-03-2021, 10:38 PM | #1 |
Some repair advice?
Just curious if this hood is worth repairing.
Maybe I should just look for a new one? If you guys were to attempt a repair like this, how would you go about it? Completely cut out and rebuild from steel?
1963 C20, small window, long bed 292, 4-speed |
08-04-2021, 09:06 PM | #2 |
Re: Some repair advice?
If I decide to fix the hood that's on my truck now instead of dropping some hefty coin on a new one, I'll be getting the whole front patch panel and fix it that way. You might be able to fix that one section, but another will probably show up at some point
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-04-2021, 09:12 PM | #3 | |
Awesome. Thanks!
08-04-2021, 09:28 PM | #4 | |
Correct?
08-04-2021, 10:42 PM | #5 |
Yes, cut old, rusty junk out, weld in new. There's some good youtube videos out there about fixing them
