10-30-2021, 10:22 AM | #1 |
14 Bolt Rear End questions
So I'm currently in the market for a SRW 14Bolt Rear End and I've read a few forums and Pirate 4X4 sites and just wanted to get some input.
I'm looking to purchase a 14bolt SRW out of a 88-98 OBS, and was curious if I would have any issues with it fitting a 1985 C30 or should I continue my hunt for a 73-87 SRW? I'm sure this is out there, but I've not had any luck so far. Thanks everyone |
10-30-2021, 10:39 AM | #2 |
Re: 14 Bolt Rear End questions
What is in the 85 now
10-31-2021, 09:29 AM | #3 |
You will need to verify what I’m typing
But I know there are different widths of these axles depending on whether the donor truck was a dually, a fleet side, or a cab chassis. Also I’m almost positive the spring perches were further outbound on the 88-99 generation trucks. The frames were wider So with that said I think there are about 5 different axles that at first glance look the same
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD 73 k5 gm crate 350-265 / sm465 / np205 3.73 posi |
10-31-2021, 09:59 AM | #4 |
The spring perches are different spacing between square body and OBS. Not a big deal if you can weld, but not bolt in.
11-01-2021, 05:55 PM | #5 |
The only reason I would go with the later axle would be to widen my rear end track width.
It will need new spring mounts, and the shock mounts relocated. I have done it with the 14 bolt SF, and it takes a bit of work. To get it to line up, but I was happy with the results. Prefect rear stance while being able to rotate tires all with out spacers. |
11-03-2021, 02:10 PM | #6 |
Thanks everyone. I found a 73-87 SRW 14bolt locally
11-03-2021, 06:22 PM | #7 |
Just a heads up .
2wd and 4wd have different shock mount positions. And there is 3/4ton will not bolt in to 1ton as they have the wider spring spacing . There is 3/4 ton crew cab 2wd that is 1ton under its body .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
11-03-2021, 08:59 PM | #8 |
To clarify, one ton trucks (or 30 series) have spring perches at 40.5” while 3/4” ton trucks have spring spacing at 42.5”
11-25-2021, 12:11 PM | #9 |
Is this measurement center to center?
Desert |
