Old 07-20-2022, 06:32 PM   #1
saddletramp
72 Sierra Grande
Afternoon Guys I have a question to ask I had my stock 350 rebuild im ready to bring it home I've had a major family issue to address my motor Will be in my garage for now till I can get back on my project do I need to do anything with the motor till I can get started up again probably 6or8 months. Thanks Guys Saddletramp
saddletramp is offline   Reply With Quote
Old 07-21-2022, 09:45 AM   #2
MARKDTN
Re: 72 Sierra Grande
Is it assembled or a bunch of machined parts?
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 07-21-2022, 11:19 AM   #3
cwcarpenter98
cwcarpenter98's Avatar
The biggest thing is to keep dust, dirt, metal shavings, etc. out of the engine while it's sitting. Keep any holes leading into the cylinders or crankcase covered with painters tape at a minimum. You could also drape a towel over the whole thing after taping the holes.
Keep any grinding, drilling, or welding away from the engine so you don't throw metal shavings on it
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 07-21-2022, 04:17 PM   #4
saddletramp
Thanks for the response guys the motor is all assembled
Old 07-21-2022, 05:32 PM   #5
cwcarpenter98
Wouldn't be a bad idea to ask your engine builder what he would recommend for storage, especially if there's a warranty on his work
Christian Carpenter
Old 07-21-2022, 05:44 PM   #6
Accelo
Accelo's Avatar
I stored a rebuilt motor for over 25 years.
I had some family issues, a divorce.
I left the rockers loose so the cylinders were sealed.
I did pull the heads, for inspection, before I started the motor.
Motor was installed in the car. Only issue was some mice had crawled through the exhaust system and stored food in the exhaust port.
It had the factory ram horn manifolds on it and the primary exhaust pipe installed. Which was no where near the floor.
Since it was food, and dry, it didn't cause any issues with the valve. Started and ran fine.
Tape it up and keep it dry. It will be fine.
Cheers.
Accelo is offline   Reply With Quote
Old 07-21-2022, 06:29 PM   #7
saddletramp
Thank you
Old 07-22-2022, 09:21 AM   #8
57taskforce
All about them K’s
57taskforce's Avatar
I like to put a large heavy mil contractor type trash bag over them and tie it off tight with a zip tie if it’s still on the engine stand, or in an engine crate. Engine bags work good too but the contractor bags are heavier plastic.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 07-22-2022, 09:48 AM   #9
saddletramp
It will be on my engine stand I'll try that Thanks
