02-25-2024, 02:59 PM | #1 |
Flat tappet lifters
I recently decided I am going to keep the big block in my Plan D truck. A week ago I scored a edelbrock intake, good heads, and a old Crane 272 cam.
The lifters were not stored in a way to be able to reuse. So obviously Crane is no longer around. Which brands of lifters are considered the best now? Are Rhoads lifters worth over double the price vs Comp cams? |
02-25-2024, 06:31 PM | #2 |
Moderator
Re: Flat tappet lifters
If you are interested in longevity of the cam / lifters project, I would recommend you buy a complete Cam and Lifters set, all new.
The reasons are as follows: The "old Crane 272 cam" is an unknown item with respect to wear and tear run in and general condition. You have to wonder why lifters were not included? Did they fail? Run dry? poor break in? etc. If the supplied cam has been run, has it lost the offset angle ground into each lobe to ensure the lifters spin correctly? Remember, its not only the cam/lifters you need to replace if something goes wrong, you also have gaskets, materials, oil and filter, plus other items. If the cam chews up the new lifters, the metal dust will go everywhere inside the engine. Just my 2 cents worth....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
02-25-2024, 11:35 PM | #3 | |
02-26-2024, 12:20 AM | #4 |
02-26-2024, 03:06 AM | #5 |
02-27-2024, 10:22 AM | #6 |
Active Member
On flat cams I will use only GM lifters, they have a hardened disc on the bottom of the lifter rather than case hardening the lifter body. Have broken in 4 engines in the last three years with these lifters and have had no issues (cams were older new cams still in their box). I am going to roller cams in the future due to poor cam cores available today.
02-27-2024, 03:01 PM | #7 |
One of the cam companies makes "cam saver" lifters that supposedly flow more oil to the cam. I am considering trying them next time I buy a cam.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
02-27-2024, 05:51 PM | #8 |
My experience...comp bad...howards good. YMMV -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
02-29-2024, 03:27 AM | #9 | |
I need .990 lifters so GMs are to small |
02-29-2024, 03:33 AM | #10 |
03-12-2024, 09:02 PM | #11 | |
03-12-2024, 10:18 PM | #12 |
I read the GM lifter suggestion from THI, I've been messing with a different brand lifters trying to solve a ticking noise for some time now.
I found the GM ones at Summit, ordered and installed. My GM lifters said they were still made in USA. I've got about 100 miles on them now, all is quiet. Thanks for the suggestion THI.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
03-14-2024, 09:08 PM | #13 | |
03-15-2024, 08:09 PM | #14 |
I believe Myself. The patterns can't really be that different
03-23-2024, 05:12 PM | #15 |
If it is a solid lifter look for some with EDM oil holes on the face. They put oil on the cam lobe as it runs.
