![]() ![]() Join Date: Jan 2005
Tach/Vac Gauge Cluster
Here are the details on this cluster:
Tach - Brand new reproduction Vacuum - Brand new reproduction Fuel, Oil, Temp & Battery Gauges - These are nice OE gauges that have been bench-tested. They all function correctly. Speedometer - This is a nice clean OE unit. I tested it by spinning it with a servo motor at precisely 1001 RPM, and it read 60mph, which is correct. I lubricated it and reset the odometer back to zero. Front Tin - OE - I added factory-style formed openings for the tach and vacuum gauges Back Tin - OE - This is a factory original tach tin Lens - OE - This is a FACTORY ORIGINAL TACH/VAC lens. The backlighting will work correctly on this lens unlike the reproduction tach/vac lenses that have the green paint on the wrong side which causes them to be dim at night. It has typical swirl marks on the front from being cleaned over the years Bezel - Reproduction 67-68 style Printed Circuit - Brand new reproduction Bulbs - Tested good $425 + shipping Money order preferred, PayPal accepted (you pay fees) Last edited by pjmoreland; 01-19-2024 at 07:12 PM. |
Re: Tach/Vac Gauge Cluster
Here are some photos taken during testing
More testing photos
A few more
![]() Join Date: Aug 2013
PM sent.
Thank you. |
Sold to Cali72K20
