Old 02-06-2024, 10:12 PM   #1
pontiacvince
pontiacvince's Avatar
Starter/ignition issue
I am having an issue that has just started. I got in my '71 and started it and the starter stayed engaged. I turned it off and tried to restart, and there was nothing. Went out and tapped on the starter housing and it eventually started and I drove home. Tried to restart, and the starter engaged with the key in the "On" position (not the start position). Did that repeatedly. Just replaced the starter with a new one with new solenoid. No change. Still engages the starter with the key in the "On" position. Could this be the ignition switch or something else I'm missing???
pontiacvince is offline   Reply With Quote
Old 02-07-2024, 04:26 PM   #2
HO455
HO455's Avatar
Re: Starter/ignition issue
Try putting the transmission in drive and see if it happens. If not then take a good look at the connector on the starter switch. They are a known failure point.
If so then you have some wires shorted together after the neutral safety switch and before the solenoid.
And ignition switch failures are pretty common especially with some of the parts sold today. For more ignition switch information see this thread.
https://67-72chevytrucks.com/vboard/...d.php?t=818861
And as I said on the truck side "Let us know what you find."
With more information I came to a different conclusion here. It may be that both the starter and the switch are/were bad at one point
RIP Bob Parks.
Old 02-12-2024, 08:43 PM   #3
pontiacvince
After replacing the starter/solenoid and still doing the same thing, I pulled the switch (new) from the dash, checked all wiring, etc. All good. Then I took the bakelite off the back of the switch and you could see carbon build up between two of the contacts. I was told that the aftermarket switches have a problem because they are too close together and eventually arc across. I cleaned all the carbon buildup out and used a small file to widen the gap. Cleaned it again, and then filled the gap with some super glue. Works perfectly!!!
Old 02-12-2024, 08:53 PM   #4
Getter-Done
Getter-Done's Avatar
Good News.
Thanks for Sharing the Fix.
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 02-13-2024, 08:57 AM   #5
HO455
HO455's Avatar
Great work! Any chance you took some photos? I'd like to add them to the ignition switch thread I started.
RIP Bob Parks.
Old 02-13-2024, 08:21 PM   #6
pontiacvince
I ordered a new switch from LMC and got it AFTER I had already fixed the other one. I snapped these pics from it. The two COPPER contacts that are too close together are visible on one side. A small file to open that gap slightly is all that is necessary. As I said, after it is opened up and cleaned, a small amount of super glue was used to fill it in. Be sure NOT to get the super glue on the contacts and let dry thoroughly.
CAUTION: The small brass contact has a small spring underneath. Be very careful when disassembling!!! The brass contact goes as shown.
