Old 01-24-2015, 01:57 PM   #1
Evilclone13
Evilclone13's Avatar
Major rust in "A" pillar, repair ideas needed ...
I have a 65' GMC that has major rust in the "A" pillar that is in need of repair/replacement. I'm not having any luck finding a patch piece for this section (which I didn't expect to find). That being said, I know most people will recommend swapping the whole cab out with another donor, but I really don't have access to the equipment you would need to swap out the cab.
If you were going to tackle repairing this section of the cab, how would you go about it. I have access to sheet metal (not sure what thickness to buy?) and I have my own gas Mig, plus hammers and dollies. I've never repaired a body section like this, especially one that has this kinda of curvature and structural importance.
Any and all advice is appreciated ... Thanks!
I like anything that turns money into noise ...
Evilclone13 is offline   Reply With Quote
Old 01-24-2015, 02:44 PM   #2
Re: Major rust in "A" pillar, repair ideas needed ...
Easiest way would get a new cab and use it. Other thing if you want to keep your cab would find one that the top is in good shap, and cut it off at the pillars, and weld the new top onto the lower portion of your cab.
With that mush rust there I wonder how much of the firewall/floor areas are deteriorated
Old 01-24-2015, 06:33 PM   #3
LT1 Burb
LT1 Burb's Avatar
I have a complete roof but it would be expensive to ship.
LT1 Burb is offline   Reply With Quote
Old 01-24-2015, 07:44 PM   #4
cheessee
Ship it by grey hound is a lot cheaper sometimes
cheessee is offline   Reply With Quote
Old 01-24-2015, 08:24 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You can technically section and re-skin that portion, if you had the good cab section to replace it with. The problem is usualyl that the underlying metal also rusted, and you wind up "chasing" rust further into the other panels that you first thought.
You also have to be careful to make sure that the windshield will ever seal again.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-25-2015, 04:40 PM   #6
gavenb
i dont think its so horrible a new cab is necessary. I'd start by cutting it out and seeing what youre dealing with.
gavenb is offline   Reply With Quote
body, cab, repair, rust
