Old 03-02-2022, 03:48 PM   #1
robbieg454
1986 C10 steering gear swap
I have an 86 c10 I'm restoring and want to know if I can use a steering gear from a 85 K10. They have separate part numbers. Just want to know what is the difference between the C and the K boxes. Thanks
robbieg454 is offline   Reply With Quote
Old 03-02-2022, 05:21 PM   #2
Mathew21
Mathew21's Avatar
Re: 1986 C10 steering gear swap
This reply was copy and pasted from another site.
With a 2wd steering box the pitman arm moves side to side and the 4wd moves front to back. The sector shaft is different which won't allow you to just swap pitman arms. The 4wd box has a through bolt holding the pitman arm onto the sector shaft whereas a 2wd bos uses a nut and washer to hold it on. You need a 2wd steering box if you're doing crossover steering otherwise the 2wd box won't work unless you install a 4wd sector shaft. I believe the year difference for the fitting change was 1980 and earlier for the flare fitting hose and 1981 and later for the metric O-ring style hose.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 03-03-2022, 10:10 AM   #3
robbieg454
perfect thanks that's what I need to know.
