![]() Join Date: Nov 2018
vibration maintaining cruising speed
hi fellas
68 c10 350 700r4 the truck is running great but if i'm cruising +-60mph with about 1/8 throttle to maintain speed i get a vibration that feels like i'm running over small shoulder bumps. if i let off the gas it goes away, if i give it a touch of gas it goes away. i can't tell if its the engine or transmission. any ideas what to look for? or just avoid 1.8 throttle position? thanks steve **** i'm thinking it's getting lean between idle circuit to cruise Last edited by steeeeeve; 01-12-2021 at 06:24 PM. |
Re: vibration maintaining cruising speed
Hard to say what it is and I'm certain others will chime in with suggestions. I usually start with the easy stuff and use the process of elimination.
1. Any balance weights missing from any of your wheels? 2. Check to see that motor/transmission mounts are ok 3. Did it just start happening recently?
66 GMC Suburban Custom 66 Chevy K10 Suburban |
Might be a transition spot between idle and power circuits in the carb.
Try in 3rd gear at the same speed to see what it does. If no vibration try in 3rd gear at the same rpm as it is in o/d. |
Senior Moment
![]() Join Date: Mar 2002
1st thing I would check would be U Joints and Center Support Bearing
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
![]() Join Date: Aug 2019
I would also try putting in neutral, then vary the throttle.
Just here to tinker
![]() Join Date: Jun 2008
x2
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Who Changed This?
![]() Join Date: Jan 2013
Check if any exhaust equipment is close to anything. At that speed and torque, an exhaust part can lightly touch something and cause a noise. Coasting and harder acceleration could change the light contact and reduce the noise.
Is the truck lowered? It could be the driveshaft angle as well as worn driveline components.
thanks for all this info guys. i will check the suggestions and look for witness marks.
more info on the truck new 350 from jegs installed last year rebuilt 700r4 installed a few month ago from a reputable trans shop new driveshaft/u-joints (converted to 1 piece during trans swap) truck is bagged new tucked exhaust as of about a week ago. shorty hedman headers. i've noticed it make the rumble if my foot is just slightly on the gas pedal at cruising speed. just a touch more and it goes away. then during slow speed acceleration i think i can feel the rumble in that sweet spot for just a short instant. |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
I have this, I think, but in my case it is right around 40mph. It's like a harmonic distortion/low rumble and what you describe with giving it a bit more gas alleviates it - though if the speed limit is 40mph that is not much of a solution ha!
I suppose the same suggestions apply, even though I don't have a 700r4 but a TH350 (with 2 piece drive shaft) ? I wished I had a 700r4!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#12 | |
but ya. I could hold the pedal in that position and have it make that rumble strip noise for miles and miles then just give it just a touch more gas and it goes away. so weird. |
