Future TOTM Winner
NP205 output shaft swap question.
I think the answer is yes, but I am hoping for some confirmation. On one of the newer style 205s that has a round input and slip yoke rear, can the slip yoke rear be removed and replaced WITHOUT MODIFICATION with an older style "u" bolt yoke and output shaft. I don't mind robbing any and all parts from my original 72 transfer case to make this happen, I just don't want to go through any machining or after market parts unless I have to.
Basically I want this... to look like this... by just swapping around factory parts.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Future TOTM Winner
Re: NP205 output shaft swap question.
anybody...
I think there is a difference in bearing bore size. Pirate4x4 has TONS of good info on the 205 and input/output swaps.
Future TOTM Winner
Redcap, I think the bearing difference you are talking about is on the INPUT shaft. I can't find anything saying one way or the other about the rear. Pirate does have a lot of info about the 205 but haven't been able to turn anything up about this in particular. A few guys have mentioned making the change but nobody gives details and I don't DARE ask a question on there due to the scolding I would receive for being a "dumb ass noob"! If none of the friendly faces here can help me, I guess I will just bite the bullet and make a post over their. Thanks.
Future TOTM Winner
Figured I would update this in case someone else wanted to know later on...
Dug a little deeper at Pirate and found this. Looks like it will work like I want. See post #9 and #10. I hope they are right.
#6 | |
