11-25-2021, 03:25 PM | #1 |
Leaking master cylinder cap.
Hi all, I have a '66 C10 with a leaking master cylinder cap. It is not over full. For some reason all the fluid came out the rear port. This is a new master that got all ugly from the fluid. I refilled and bled. Now I see why it is getting emptied. Has anyone else had this problem? Any ideas? Thanks in advance...
11-25-2021, 04:22 PM | #2 |
Re: Leaking master cylinder cap.
New cap and rubber gasket? Tightening the wire hold downs is a pain but took care of the leak on my cap.
11-25-2021, 08:38 PM | #3 |
I have a similar master. I went a couple years of driving before checking the fluid again. When I did that, a little bit of crustiness had built up on the seal. When I put the cap back on, I noticed that it started leaking. Took it off again, cleaned the crustiness off the rubber on both sides, then took a razor blade to the sealing side on the master to make sure it was clean and flat. I haven't had a leak since doing that
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-26-2021, 12:58 AM | #4 |
I installed a new master cylinder last year that is the same style as yours, and the cover leaked right from the beginning. I ordered a MCAK012 cover from opgi.com, and it hasn't leaked since. This cover is overpriced, but it did solve the problem.
https://www.opgi.com/brake-systems/m...l-mcak012.html |
11-28-2021, 06:51 PM | #5 |
Thanks all, new cap, gasket and tightened the hold downs. No more leak!
11-28-2021, 11:30 PM | #6 |
Right on!!
11-29-2021, 02:30 PM | #7 |
@grubsster.....
Thank you for updating the status. Would you care to share the p/n or any specific info related toward the 'fix' that can be used for future reference should others see this thread?
11-29-2021, 05:19 PM | #8 |
Sure, I used the original cap from my old master cylinder which seemed to be of better material than the new master. Installed the retaining clips upside down in the vise and bent both sides inward, at the point where they go in the master, about 1/8th of an inch to "shorten" them a little. Used a 42071 dorman gasket.
Hope that helps. |
11-29-2021, 06:21 PM | #9 | |
11-29-2021, 08:32 PM | #10 |
Thanks for the update. My brand new MC looks like it is seeping from under the cover but only when I fill it all of the way to the top with brake fluid. I will look into these fixes.
It's not rust, it's called patina Trying to bring a 68 Panel Truck back from the dead. 396 Big Block, 4 on the floor, and a whole lot of rust. |
11-30-2021, 01:09 AM | #11 |
When you are filling, make sure you are allowing room for expansion. I fill mine as in the picture. Others may do differently, but that works best for me.
12-02-2021, 02:58 PM | #12 |
Those type of caps always leak. Mine was the same way. I spent the $150.00 and purchased a Wilwood MC. Best money spent, but I hate leaks.
I get that you would need to bench bleed the new MC prior to installing then re-bleed your brakes. I know that's what I ended up doing and it was still worth it (to me). Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
