05-16-2023, 08:23 PM | #1 |
Who Me?
Shocks for a 2" drop 97 Tahoe
Hello all, I seem to remember something about using Dodge Dakota front shocks for a 2" drop 97 C1500 or Tahoe.
I tried searching for that thread and came up empty. I did find some shocks that mount up the same, but not sure about length. Thanks for the help. Steve
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
05-16-2023, 11:12 PM | #2 | |
Re: Shocks for a 2" drop 97 Tahoe
I have a 92 Dakota so I measured the shocks for you. They are about 13" long at installed height, which is about 2" less than my 2500LD which has the same shocks as the 1500.
05-17-2023, 05:11 AM | #3 |
Mine was lower than 2” up front n used stock shocks. Worked fine.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
05-17-2023, 12:22 PM | #4 |
Who Me?
Thank you for that!
05-17-2023, 12:23 PM | #5 |
Who Me?
I was concerned that they may bottom out.
05-17-2023, 01:20 PM | #6 |
driving is in my blood
Why not just buy actual drop shocks that are valved for the shorter travel?
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-17-2023, 01:43 PM | #7 |
Who Me?
I agree, because the cost is about double and my budget is tight.
05-17-2023, 02:10 PM | #8 |
I don't remember it ever bottoming out. I had more of a problem with the rear, tho no really a problem, but I would hit the bumpstops on a good bump, even after trimming bout half off.
05-17-2023, 02:51 PM | #9 | |
Yea, now that I think about it. A dropped spindle would use the factory shock. So would a dropped spring because the control arm still would bottom at the same spot, it would just get there faster. I don't know what a dropped control arm would need but those are usually 3".
05-17-2023, 05:23 PM | #10 |
Who Me?
I lowered mine with springs. I would agree with stock shocks with drop spindles.
05-17-2023, 05:38 PM | #11 | |
I can understand the reasoning for using the shorter shock, the only thing I would worry about with that is it not having enough travel at full suspension droop.
05-18-2023, 12:47 AM | #12 |
On pretty much any vehicle you can completely remove the spring and the bump stop bumper. Jack the suspension up until it is bottomed metal to metal. A stock length shock will not be bottomed out in this position. Factory designed suspension this way.
As mentioned by some, ride on lowered vehicles that use shorter or "drop shocks" can be made even worse because now you have not only limited up travel with the shorter springs, down travel is now limited by the shock. Shock valving has to do with the type of shock not the length. The dampening of the shock is linear throughout the shock movement except on some specialized shocks like the internal bypass shock on the front of my 72.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
05-18-2023, 04:05 PM | #13 |
Who Me?
Thanks for the info everyone!
05-22-2023, 07:59 PM | #14 |
It is not linear, otherwise shocks wouldn't have a high speed and low speed compression damping circuits [obviously only high end units do, but the principle is the same]. Shocks work by forcing fluid threw restrictions. The restrictions don't change size to accommodate fluid speed, therefor changing the valving in essence depending on the speed of motion put into it.
05-23-2023, 01:11 AM | #15 | |
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 05-23-2023 at 01:28 AM. |
