02-16-2010, 03:23 PM | #1 |
orange wire on Heat/AC Selector
I've got a 1977 burb. Finally getting around to installing the wiring harness and A/C stuff. The vacuum selector attached to the heater/AC panel has a orange wire running to nowhere. It's even shown like that in the wiring diagram. Any ideas where this goes, if anywhere? Many thanks, Tom
02-16-2010, 06:13 PM | #2 | |
Re: orange wire on Heat/AC Selector
What diagram are you looking at, can you post it? Orange usually is used for high speed resistor bypass and blower motor feed wire.
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
02-16-2010, 08:27 PM | #3 |
Fixit,
It's a 1977 wiring diagram. The little square box in the corner calls out Air Conditioning, RPO C-60. The selector switch is just above the title box. It shows a 16 ORN with a P/N 2962793 connector going to nowhere. Thanks, Tom |
02-19-2010, 01:27 PM | #4 |
Just found out that that orange wire is for the "recirculation over ride switch" Don't know what that is, where it hooks up or what it does. I assume that it's a power wire, since it's orange. Going to leave it alone for now. Having trouble with the fuse blowing when I put the fan on high. Changed out the switch with another used one and it doesn't even work on high. Ordered a new switch from Classic yesterday. Hopefully that will fix the problem.
