Old 11-24-2018, 09:38 PM   #1
davee60
Junior Member
Front bumper brackets 2wd vs 4wd
Hope everyone had a good Thanksgiving!
Does anyone know if the front bumper brackets are different, between a 63-66 C (2wd) vs K (4wd) model? Or any pictures I could use for comparison? Thanks.
Dave
1966 K10 Suburban
davee60 is offline   Reply With Quote
Old 11-25-2018, 08:38 PM   #2
davee60
Junior Member
Re: Front bumper brackets 2wd vs 4wd
In case anyone is wondering, the reason I ask this is because the assembly manual calls out different part numbers between the C and K models. I haven't been able to verify that there are any physical differences though...
Thanks in advance if anyone can provide further info.
Dave
1966 K10 Suburban
Old 11-26-2018, 01:07 AM   #3
aotte1
Yes, the front bumper brackets are different. Will try to post photos tomorrow.
Les
aotte1 is offline   Reply With Quote
Old 11-26-2018, 11:18 AM   #4
davee60
Junior Member
Les
Les, thank you very much, I really appreciate it! Pictures would be great. I haven't been able to find any repop 4wd brackets, although some vendors do list the same bracket for C/K models. Whoever mounted the bumper on my K Suburban really twisted the brackets to get them on, so I'm hoping I can find K brackets or at least figure out how to modify the C brackets. Thanks again!
Dave
1966 K10 Suburban
Old 12-03-2018, 12:50 AM   #5
aotte1
Dave,
Photos showing both K10 and C10 front bumper braces.
The K10 front bumper braces are the ones not cleaned. The C10s are cleaned and coated.
Les
Old 12-03-2018, 12:53 AM   #6
aotte1
A few more
Old 12-03-2018, 04:04 PM   #7
davee60
Junior Member
A few more
Les, thank you very much, this is extremely helpful! Now, my task is to find a pair of the K10 brackets... If you have any "insight" on where I might find a set please send me a PM.
Thanks again for the pics!
Dave
1966 K10 Suburban
Old 02-28-2021, 11:41 AM   #8
murdoc
murdoc's Avatar
Attempting to revive this thread. I doubt I'm the only one needing K10 front bumper brackets.
Is there an aftermarket solution to getting K series front bumper brackets yet?
I appreciate all the photos posted here, it gives me hope that if there still isn't an aftermarket bracket available, c10 brackets could be used with minor modifications to fit a k10 application.
Has anyone taken this approach? It looks as though the geometry is the same at the bumper end, and only changes on the other end where it bolts to the k10 frame.
I feel like my only option at this point would be to cut the c10 brackets in half, and fab the proper fitment for the end that bolts to the frame.
Any feedback on this approach would be appreciated!
murdoc is offline   Reply With Quote
