10-29-2020, 12:22 PM | #1 |
Drop Spindles - why won’t they fit ?
Hey guys. I’m looking at a set of drop spindles off Kijiji but I’m scratching my head as to why they won’t fit, or will they ? Part # CP4S2. The box says works with 71-87 1.25” rotors, is that if you are doing a disc conversion?
Summit racing says it fits 63-70 C10. I have a 72 C15 with factory disc brakes. Why would these fit a 70 but not a 72? |
10-29-2020, 12:30 PM | #2 |
Re: Drop Spindles - why won’t they fit ?
The used smaller balljoint and tie rod spindles up to 70 I believe.
1970 C10 l/b 292/4spd Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062 |
10-29-2020, 12:37 PM | #3 |
Bnorth is correct you will need to use earler tierods and balljoints to use the 63 70 spindles
10-29-2020, 04:24 PM | #4 | |
10-29-2020, 04:26 PM | #5 |
Correct. Those were the exact part numbers I just installed on my 67 and they required ball joints and tie rods for 67-70 models.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2020 Toyota CH-R 2020 Acura MDX |
10-29-2020, 04:36 PM | #6 |
Thanks Everyone! Appreciate the response and clarification!
