Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Closed Thread
Old 03-05-2006, 02:13 PM   #1
tnblazerk5
User #12137
tnblazerk5's Avatar
plug wires for ram horns and hei dizzy?
seams to me a while back sumbody made a post about plug wires for hei dizzy and ram horns at the time i had nothing with ramhorns on it and well now i do and needin that info but cant find it
thanks ,robb
tnblazerk5 is offline
Old 03-05-2006, 02:16 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: plug wires for ram horns and hei dizzy?
I use 78 Corvette wires. Perfect fit, as the Vettes used ramshorns and HEI.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline
Old 03-05-2006, 02:22 PM   #3
tnblazerk5
User #12137
tnblazerk5's Avatar
cool thanks
i was thinkin corvette but couldnt remeber the year
thanks again
Old 03-05-2006, 06:03 PM   #4
67sss
67sss's Avatar
TX- is that for the stock position for the wires, or the straight boot on the plugs? Thanks.
67sss is offline
Old 03-05-2006, 06:27 PM   #5
6T8
Active Member
Anybody know the vendor here that sells the mounting brackets for this hei setup? Thanks......Rick
6T8 is offline
Old 03-05-2006, 06:34 PM   #6
Tx Firefighter
They are 90 degree ends. The wires are perfect length. They are long and run underneath the manifolds like they are supposed to. No danger of burning wires by running them over the valve covers and manifolds.
Old 03-05-2006, 06:35 PM   #7
Tx Firefighter
What mounting brackets are you asking about? Just run the wires from the HEI to the plugs just like the stock points wires were run.
Old 03-05-2006, 09:04 PM   #8
pjmoreland
pjmoreland's Avatar
http://www.gmcpauls.com/Engine%20&%2...n%20Mounts.htm
GMC Pauls sells the manifold heat shields, the plug wire clips that go under the shields, the clips that go on the oil pan, and the clips that go on the back of the block.
pjmoreland is offline
Old 03-05-2006, 09:30 PM   #9
woodridge
woodridge's Avatar
Robb, I used a set for a 75 vette. Here are a couple of pics.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline
Old 03-05-2006, 10:07 PM   #10
matthufham
why are the passenger side, front 2 wires so long?
matthufham is offline
Old 03-05-2006, 10:20 PM   #11
kaycee
kaycee's Avatar
Nappa #700254 run them like TX and woodridge says no problems here
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline
Old 03-05-2006, 10:29 PM   #12
da-burb
"Ochre Ogre"
da-burb's Avatar
There is also a clip mounted to an oil pan bolt that would hold the wires up and out of the way.
I have run many sets of these wires on various trucks. I usually buy Napa and what I usually find is the shortest wire could be an inch longer and the longer wires are usually an inch or 2 longer than they need to be. But they work and my trucks were beaters. Otherwise custome cut and fit are the way to go for a show truck.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline
Old 03-06-2006, 12:03 AM   #13
woodridge
woodridge's Avatar
I believe the vette has a shield the wires ran in down low and back up to the plugs, don't know why the general did that. I did shorten them before installing the motor.
Old 03-06-2006, 12:10 AM   #14
speedracer
Blank
speedracer's Avatar
the 77 vette came with all the cap and all the wires hidden under stainless steel housings for a clean look. I used the wires and the lower housing from a 76 on my truck and it looks great. I never was a fan of the cover over the dizzy, never put it back on the vette after motor rebuild. I sure you guys can find some pics on the net.
http://www.brcorvetteclub.com/events...Years/1977.htm
this is the car 2003 on display in nashville for corvette's 50th I can't find any good pics under the hood. oh yeah and that me havin a ball in the background with the blue shirt
1969 lwb 4/6 drop 17x8-18x10 torque thrust II's 327-420hp 2004R 3.73 posi.
1977 Corvette 350-375hp 4speed, silver show car.
2002 S10 xtreme, work truck
2004.5 VW jetta GLI 1.8T 6speed, weekend warrior.
2013 Audi A3 TDI, the wife's car
speedracer is offline
Closed Thread
