Old 10-21-2007, 01:20 PM   #1
abadsvt
abadsvt's Avatar
Project "Dream Truck"
Here i go again starting over. This is what happened. I was looking for an LS1 motor for my other project when i came across a complete rollin drivetrain from a 2002 Corvette (C5) for the basically the same price as a motor and tranny. So I decided to start over. Well kind of. I am using some of the parts (the cab, wheels and tires, shockwaves) from the other build.
This time i wanted to do things a little different. The first frame i built came out great but I think i was kind of lucky that everything ended up level and square so this time i didn't want to test my luck. So i decided to build a frame table and then build a jig on top of that. The frame table is roughly 15' long by roughly 66" wide. After it was built i got it perfectly level all the way around then bolted it to the floor so it can't move. Then i built a "jig" on top of it to hold the frame as i build it. It took a little while to get everything were i needed it to be and be squared and leveled but i finally got it. Building this jig was the best thing i have ever done. It only took me around 2 half days to completely build the new frame and have it fully welded. The best part is i didn't get any movement from welding. I moved around welding in different spots which helped but the jig kept it exactly were it needs to be. I plan on building the entire truck on this frame table. I have to remove a few support pieces after I am done welding on the gussets to allow room for the suspension parts and wheels. Anyways enjoy!
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 10-21-2007, 01:22 PM   #2
abadsvt
abadsvt's Avatar
Re: Project "Dream Truck"
A few more
(Project truck)
Old 10-21-2007, 01:25 PM   #3
abadsvt
abadsvt's Avatar
Here is a pic of the rollin chassis how i bought it. Someone tried to build there own frame for a 67 nova but didn't do such a great job.
(Project truck)
Old 10-21-2007, 01:35 PM   #4
abadsvt
abadsvt's Avatar
The frame table represents the ground and the jig is setup at ride height which is 8 1/2" to the frame rails off the ground. That was the height to put the front fender just above the tire so i can turn the wheels easy without rubbing.
Josh
(Project truck)
Old 10-21-2007, 03:35 PM   #5
kyull67
kyull67's Avatar
This project is going to be AWESOME!
kyull67 is offline   Reply With Quote
Old 10-21-2007, 04:35 PM   #6
Frizzle Fry
Frizzle Fry's Avatar
That's the way to go! BTW I just read about the feature truck in the latest Classic trucks. All C5 including rear transaxle but with a driveshaft instead of a torque tube. Looking into it now
Frizzle Fry is offline   Reply With Quote
Old 10-21-2007, 09:16 PM   #7
abadsvt
abadsvt's Avatar
Is that the current issue that is out or the one that is coming out? I wouldn't mind looking at that also.
Josh
(Project truck)
Old 10-21-2007, 11:25 PM   #8
Frizzle Fry
It's the Dec issue with the bare metal pre-55 truck on the cover.
Old 10-21-2007, 11:53 PM   #9
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I think you should give me your old frame !!!
Sweet, can't wait to see it done this time around !!!
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-22-2007, 08:39 AM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That thing is going to be sweet. Can't wait to see the build on this thing.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-27-2007, 11:58 PM   #11
abadsvt
abadsvt's Avatar
Well i got a little more done today. I got all the frame gussets on and fully welded. It took longer than i originally thought it was going to take. I ended up spending a few hours on it so it wasn't too bad. I like the end result though. Definately stronger which equals safety. Anyways here is a few pics.
Josh
(Project truck)
Old 10-28-2007, 12:41 AM   #12
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
what are you doing with the old frame? Dibs if possible
Angelse68cal is offline   Reply With Quote
Old 10-28-2007, 12:55 AM   #13
abadsvt
abadsvt's Avatar
Well i am not sure. I thought about selling it but there still are a few things that need to be done on it before i could let it go. Plus i have too much money in the frame for most people to be interested in it. If you are really interested send me a pm and we can talk.
Josh
(Project truck)
Old 10-28-2007, 07:14 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
Nice welds...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-28-2007, 12:29 PM   #15
Frizzle Fry
Looking good!
Old 10-28-2007, 02:17 PM   #16
ColoradoK5
ColoradoK5's Avatar
Nice project!! can't wait to see more.
ColoradoK5 is offline   Reply With Quote
Old 10-30-2007, 03:46 PM   #17
abadsvt
abadsvt's Avatar
I got a little more done yesterday. I was able to fab and install the cab supports and remove a few of the frame jig support pieces to allow room for the suspension. They took a few hours but got em done. Then i decided to install the cab on the frame to double check my measurements. I love it. It is looking like a truck again, well sorta. Early next week i am buying a hydraulic tubing bender so i can bend all the tubing that will be going inside the frame rails. I have already made all the front suspension brackets for the lower control arms and the rack and pinion so once i get the tubing bent the front suspension should go real quick. I am hoping by next weekend i can have the front suspension done or close to being done. Anyways here is a few pics
Josh
(Project truck)
Old 10-30-2007, 04:55 PM   #18
Frizzle Fry
You using the vette cradles?
Old 10-30-2007, 08:34 PM   #19
revn67
revn67's Avatar
thats awesome, i am in the middle of making a frame table out of i-beams and 1/4" sheets ontop of it, its not gonna really be a jig but everything will atleast be level.....that truck is gonna look freakin awesome when done though!!!
67 small windowed,shortbed,fleetside, sbc 327, th350,12 bolt :under the knife:
71 cab for sale in parts classifieds!
2004 black chevy 1500
"finish your beer, theres sober kids in india!"
revn67 is offline   Reply With Quote
Old 10-30-2007, 09:00 PM   #20
abadsvt
abadsvt's Avatar
No i am building the suspension instead of using the cradles. I found a suspension program that gave me all the specs on the entire suspension. The only thing it didn't give me was the location of the rack and pinion so I ended up buying a front engine cradle so i can get the exact location of the rack. So far so good!
(Project truck)
Old 10-30-2007, 09:01 PM   #21
abadsvt
abadsvt's Avatar
The frame table makes a big difference! Well worth the time and effort. Thanks for the complements!
Josh
(Project truck)
Old 11-14-2007, 01:45 PM   #22
55dude
55dude's Avatar
very cool truck build! what program did you find for the suspension. i have a 55' (belair & 3100 panel) that are being considered for c5 upgrades. do you have any more pic's of your c5 or that nova chassis.
55dude is offline   Reply With Quote
Old 11-15-2007, 10:56 AM   #23
abadsvt
abadsvt's Avatar
I don't have any more pics of the c5 nova chassis that someone built. They didn't do a very good job so there wasn't any reason to take some more pics. On my frame i have got almost all the round tube installed which makes up all of my mounts for the lower control arms and internal bracing for the frame. I will take some pics sometime this week.
A c5 drivetrain would be sick in that tri fives. I would like to build one in the future. Those cars look so nice when done right and they hold there value really well which is a big plus. Are you plan on building it? Anyways talk to you soon.
Josh
(Project truck)
Old 11-20-2007, 07:32 PM   #24
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Thats gonna be killer..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-07-2007, 03:09 AM   #25
pcorriveau951
pcorriveau951's Avatar
any updates? our chassis is sweet.
pcorriveau951 is offline   Reply With Quote
