Old 11-01-2010, 03:39 PM   #1
brandy hickman
brandy hickman's Avatar
replacement gas tank
My just purchased blazer has a plastic gas tank. I can not fill it with gas, it backs up in the line, there is a small kink in the line going over the frame rail and around the body mount to the entry hole. I have moved the tank back against the rear crossmember to no avail. You squeeze the line and gas comes gushing back out the filler hole. (not good with your wife standing right there!!!) What am i doing wrong? Is there a metal hose attachment to get around the "corner"
brandy hickman is offline   Reply With Quote
Old 11-01-2010, 04:03 PM   #2
72gmguy
72gmguy's Avatar
Re: replacement gas tank
could something be wrong with the vent system on your tank? check the line from the vent next to the fill inlet on the tank, it should go up to the filler neck to allow air to escape.
72gmguy is offline   Reply With Quote
Old 11-01-2010, 04:43 PM   #3
brandy hickman
vent line is ok, i used my air compressor to check my lines
Was there a metal tube in the shape of a z from the tank to the filler hose to get around the frame?
Old 11-01-2010, 05:56 PM   #4
1949gmc
Yes, there is/was. The original tanks had a curved neck on them that went around the front side of the body mount. The repro tanks dont come with that neck... you have to use your old one.
This thread is in the FAQ section: http://67-72chevytrucks.com/vboard/s...d.php?t=212828 . It might help you some. The first pic is of the curved neck I was talking about.
1949gmc is offline   Reply With Quote
Old 11-01-2010, 08:37 PM   #5
brandy hickman
Thanks for the good info
This is frustrating
Old 11-01-2010, 09:52 PM   #6
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Here is what i did with mine. Actually works better than it ever has.
http://67-72chevytrucks.com/vboard/s...d.php?t=389497
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
