Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 01-10-2011, 12:07 AM   #1
RED67
Forever Grateful
RED67's Avatar
removing old seam sealer
can someone tell me how to remove the old seam sealer..Thanks Ronnie
R.I.P Dad 04-07-42 - 05-27-09
RED67 is offline   Reply With Quote
Old 01-10-2011, 12:53 AM   #2
peglegs
peglegs's Avatar
Re: removing old seam sealer
hey red in the summer ill be doing mine over also and considered using a heat gun but would like to hear what others have used before i try it for fear of lifting the paint, perhaps a chisel will work and heat gun the remains ?
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 01-10-2011, 09:36 AM   #3
Shane
Shane's Avatar
It will almost definitely lift the paint because it should be UNDER the paint ... i used a wire brush on a cordless drill.
Shane is offline   Reply With Quote
Old 01-11-2011, 01:02 PM   #4
72SWBChevy
72SWBChevy's Avatar
I used a wire wheel on a electric grinder. It cleaned it out fast. But I was not worring about protecting the paint.
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 01-11-2011, 01:16 PM   #5
RED67
Forever Grateful
RED67's Avatar
I already have the old paint off.. so this sounds like what I will do...Thanks
Old 01-19-2011, 08:23 PM   #6
4x4toy
Propane torch will burn it out too.
04 Yukon XL 2500 w/ Quadrasteer
61 Chevy C60, 261 inline six
86 Chevy C20 2wd, Banks 6.2
05 GMC Sierra 2500hd Duramax
4x4toy is offline   Reply With Quote
Old 01-19-2011, 08:40 PM   #7
Shane
Shane's Avatar
it will also make the roof skin look like a washboard around the edges ... be careful
Old 01-19-2011, 10:46 PM   #8
protrash64
Resistance is Futile
protrash64's Avatar
I just did this last weekend on my '66. I used a screw driver as a chisel and just tapped it along; knocked all the stuff right out. Hit it with a wire wheel and looked pretty good.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-20-2011, 01:05 PM   #9
frmula505
frmula505's Avatar
Screwdriver then wire wheel here also.
1961 GMC Suburban Custom
1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD)
1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746
1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD)
1951 Plymouth leadsled project
2005 Corvette conv. Procharged
1969 Corvette stingray
2006 Cadillac XLR-V
1950 Oldsmobile 98 custom project
frmula505 is offline   Reply With Quote
Old 01-20-2011, 01:14 PM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I used a stiff gasket remover knife and went along the edge of the vertical lip and "cut" it free from that edge. Then I came in flush with the roof panel and basically cut it out in large chuncks. After I got most of it out, I came back in with a twisted wire wheel disc (not the cup style) and removed the left over. Make sure you have a full face shield when doing this. Overall wasn't very hard or time consuming... unlike stripping the old paint off.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-20-2011, 01:46 PM   #11
463
463's Avatar
the after pic
Trueman
463 is offline   Reply With Quote
Old 02-02-2011, 01:50 PM   #12
Lauppster
3M makes a paint and rust stripper wheel; sort of looks like a Scotch Brite pad on steroids. They sell for about $6 each at most paint/body/auto stores. I use it in a drill and have had good luck with seam sealer, paint, rust, undercoating... Watch the direction you spin the drill compared to a metal edge or you will shred the wheel quickly.
Lauppster is offline   Reply With Quote
Old 02-02-2011, 10:10 PM   #13
RED67
Forever Grateful
RED67's Avatar
wire wheel and an angle grinder works fabulous...........
Old 02-04-2011, 03:50 PM   #14
67cheby
67cheby
67cheby's Avatar
this is called a WIZZY wheel , they are awesome for stripping everything, ie..door jambs, under the hood , grill etc..
67cheby is offline   Reply With Quote
Old 02-04-2011, 05:20 PM   #15
Top Banana
Top Banana's Avatar
bits of them WILL fly off and hurt like hell too......LOL
http://www.topbananaparts.com
Top Banana is offline   Reply With Quote
Old 02-04-2011, 05:31 PM   #16
67cheby
67cheby
67cheby's Avatar
ya what he said....OUCH!!! but they are worth the money they will cut you time in half !!
