04-03-2012, 04:01 PM | #1 |
This is what awesome looks like
just about finished with the 250.
the 1969 block was dipped and blasted clean. bored .060 oversize. the original crank was turned .010 on the mains and .010 on the rod journals. the rods were replaced with a set that were weight matched, shot peened, magnafluxed, and resized on the big end. new keith black pistons were used. a new oil pump went on. a new stock camshaft was installed along with new cam bearings, and drive gears. the distributor was replaced with a hei unit from a 1976 camaro. the carb came from the parts board, as well as the aluminum valve cover. the intake and exhaust manifolds are from a 292, because they were free. i'll try to do a video when i get her fired up tony
i survived cancer and kidney stones, but my kids are killing me. |
04-03-2012, 05:09 PM | #2 |
My Carbon Footprint
Re: This is what awesome looks like
Awe man.....don't stop there. Plastikote makes some great cast aluminum and cast gray paint. Pull off that darn alt and shoot the body cast aluminum while hitting the pulleys with the gray. Pull out the dizzy, take the cap off and hit the body with the aluminum while holding the dizzy upside down. Don't get me wrong....looks good but you are so close to it looking great with just a little more attention to detail!
I did my alt that way and all the pulleys/brackets with the gray. Dries quick and is tough. |
04-03-2012, 05:37 PM | #3 |
Active Member
A naked engine always looks good.
04-03-2012, 06:47 PM | #4 |
Looking good. Those are some good engines.
04-03-2012, 07:15 PM | #5 | |
but i wanna run it once like this. now the dizzy, that difinately needs attention, and thanks for the tip!
i survived cancer and kidney stones, but my kids are killing me. Last edited by beautimus; 04-03-2012 at 07:17 PM. Reason: to add additional comments |
04-03-2012, 07:48 PM | #6 |
What?
Get some high temp cast iron paint from Eastwood's for your exhaust manifold.
I just did mine, and they came out great!
Chris 1968 K20 Suburban 1972 K10 LWB PU |
04-03-2012, 08:05 PM | #7 |
My Carbon Footprint
Okay good....the alt was what I about crapped over. Looked like it came out of a swap. lol You are free to proceed!
I wasn't trying to up ya with my pic. Just showing what a little well placed paint can do. Sounds like you have it figured out. |
04-03-2012, 08:26 PM | #8 |
I like to pour used 80/90 over the intake n valve cover for a nice patina
Chevy GMC Trucks Find Of The Day https://www.facebook.com/ChevyGmcTrucksFindOfTheDay or http://ChevyGMCTrucks.com |
04-03-2012, 09:13 PM | #9 |
The Engine Whisperer
Hey.... you're missing 2 cylinders.
04-03-2012, 09:27 PM | #10 |
My Carbon Footprint
Funny I just noticed the fuel pump. Looks like GM took a BBC pump and just flipped it upside down. Never noticed that on my 250.
Below is a pic of AFTER I took Gumby's advice on adding the patina look. I will never listen to him again!!!! LOL |
04-03-2012, 10:12 PM | #11 |
^ thats how an engine should look but I don't reconize that black thing blocking the carb, never seen a truck in these parts with one
04-03-2012, 10:23 PM | #12 |
My Carbon Footprint
Obviously.....you don't have a radio. That's the speaker!
04-03-2012, 10:35 PM | #13 |
nice looking little six shooter you got there
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
04-03-2012, 10:51 PM | #14 |
Oh and OP Dave would give you hell for the engine mounted coil, epoxy coils are prone to fails as is since the epoxy holds in heat, the engine will just make it even hotter. heat kills Ign parts.
should be an oil filled can coil. the oil cools it, its not old tech, its smart tech that works. |
04-04-2012, 09:49 AM | #15 |
Ha, I repainted and detailed my 250 and it ended up looking like the photo in post 10 after I was finished dropping it in.
'66 C10 250 3-on-the-tree '68 Galaxie 460/C6 '74 914 2.0 |
04-04-2012, 05:49 PM | #16 |
C10 Club Tennessee
Very nice, it looks a tad bit cleaner then when I sold it to you
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
04-04-2012, 05:57 PM | #17 |
*** That's interesting ***
The cool part is seeing an old I6 get that kind of love. Keep up the good work.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
04-04-2012, 07:37 PM | #18 |
6>8 Plugless........
Nice I6! Spend a little more time like mentioned and it'll be getting more looks than half of the SBC's!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
