Old 07-07-2012, 04:35 PM   #1
Trucknut57
Trucknut57's Avatar
REAR Swaybar help!!!
I did the search for "rear swaybar" and came up with 7 results, or course none of those results helped.
The Truck: 1957 Chevy 3200. 72' Camaro rear axle. Gas tank under bed, right behind shocks, aluminum, hangs down approx 6" from the frame. CPP rear leaf kit, with flipped axle.
I need a rear swaybar that will fit without having to modify the things I already have.
Is it possible? Can I find a OEM from something in the pick a parts? Is there something aftermarket that I can get to fit?
I really need someplace to start looking. CPP doesn't offer anything (as far as I could find) that works with their own kit.
I finally got it back up and running, she rides smooth but has was to much body roll in the corners.
Any help will go a long way!
Wess
Somehow, the idiots survive despite their best efforts to kill themselves.
- dcozzi
Trucknut57 is offline   Reply With Quote
Old 07-07-2012, 05:55 PM   #2
solidaxel
solidaxel's Avatar
Re: REAR Swaybar help!!!
Did you try the one from your Camaro, that is what I am using
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-07-2012, 06:51 PM   #3
Trucknut57
Trucknut57's Avatar
Thanks, I didn't even think about that. I'll have to take some measurements and see if it will work. Providing I can find the dang thing!
Anymore options ?
- dcozzi
Old 07-07-2012, 07:06 PM   #4
solidaxel
solidaxel's Avatar
My Camaro rear end came with a bar when I got it for the 55 GMC, and there was not much to fab to get it to fit. The one I picked up at the PAP all I needed to do was drill two holes in the chassis on the 53, and get some new bushings (Poly) and end links
LS 3 4L70E
Old 07-07-2012, 07:26 PM   #5
Trucknut57
Trucknut57's Avatar
I know the sway bar on my Camaro mounts under the leaf springs using rubber bushings and has down rods that mount to the frame rails. So it may not mount up correctly to the 57's frame.
- dcozzi
Old 07-07-2012, 10:27 PM   #6
waybad
waybad's Avatar
here is my sway bar solution
http://67-72chevytrucks.com/vboard/s...d.php?t=521853
waybad is offline   Reply With Quote
Old 07-08-2012, 04:47 PM   #7
Trucknut57
Trucknut57's Avatar
Thanks Waybad, I'll keep that one in mind next time I'm in the Pic a parts place.
So far so good, anyone else??
- dcozzi
Old 07-09-2012, 02:26 PM   #8
_Ogre
_Ogre's Avatar
i used the swaybar that came with the 82-92 3rd gen camaro/trans am rearend
the eyes on the end of mine are turned 90* and it mounts under the axle compared to the swaybar waybad has
shop air compressor timer
Old 07-09-2012, 07:14 PM   #9
Trucknut57
Trucknut57's Avatar
Orge,
Did you bend the ends or does it come that way?
- dcozzi
Old 07-09-2012, 10:48 PM   #10
solidaxel
solidaxel's Avatar
Here is the S/bar on my 53 it cost more for the Poly bushings and end links by twice as much as the bar !!
LS 3 4L70E
Old 07-10-2012, 10:47 AM   #11
elcamino72
I have a rear bar off of a 1979 F350. I can't remember if it was a single rear wheel or dual rear wheel. It will mount on the top of the 12 bolt truck rear that I have. The end links and everything mocked up nicely. I haven't refinished it or installed it yet, but that is on my list of things to do.
Bryan Shook
Collector Vehicle Fraud - Click Here!!!
elcamino72 is offline   Reply With Quote
Old 07-10-2012, 11:27 AM   #12
_Ogre
_Ogre's Avatar
the 3rd gen sway bar centered my frame, similar to solidaxle's top picture
since my frame is boxed i heated the arm and bent each end out approx 1 inch
i've had no problem with it in 10,000 miles
orge is a round, tasty fruit; ogre is green and not so tasty
