07-29-2012, 11:07 AM | #1 |
Lokar 16" automatic floor shifter for TH400
This shifter has never been installed. It is a lokar brand 16" automatic floor shifter that bolts on to your TH400 with out modification.$140 shipped
Also available is a TH400 transmission(and torque converter out of a 72 Cheyenne $225 plus the ride. TH400 crossmember out of a 72 cheyenne big block truck. $55 shipped Last edited by Chevy072; 08-05-2012 at 04:51 PM. |
07-30-2012, 02:20 PM | #2 |
Re: Lokar 16" automatic floor shifter for TH400
anyone interested?
08-02-2012, 08:50 AM | #3 |
ttt
08-05-2012, 04:51 PM | #4 |
ttt
08-05-2012, 05:58 PM | #5 |
Would it work for a th350?
Posted via Mobile Device |
08-05-2012, 06:45 PM | #6 |
08-05-2012, 07:14 PM | #7 |
PROJECT 7DEUCE
Is that just road grime on the shifter mount?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-05-2012, 07:51 PM | #8 |
08-05-2012, 08:22 PM | #9 |
PROJECT 7DEUCE
Any idea if this will work with a bench seat? Ill check my fundage
08-05-2012, 08:25 PM | #10 |
10/30/19
I would like to get in line if it will work on a th350. Definitely interested.
08-05-2012, 08:34 PM | #11 |
Sorry,but this is for a TH400 only.
08-05-2012, 08:37 PM | #12 |
86 Scottsdale
Any idea if it would work with a bench seat? I think the height is good, but have no idea where the stick would be positioned in relation to my bench.
08-05-2012, 08:42 PM | #13 |
PROJECT 7DEUCE
Ill get inline on this..
08-05-2012, 08:46 PM | #14 |
86 Scottsdale
Did some more reading online. Looks like the positioning is pretty flexible with the adjustments built in. I'll take it if it gets to me.
08-05-2012, 09:11 PM | #15 |
I think this will work with a bench seat because it is adjustable. The following is from Lokar's website. I will call Lokar in the morning to confirm.
•Positive Lock-Out in Park and Neutral •Neutral Safety Switch •Operates with solid adjustable linkage •Utilizes high quality rod ends •360 degree lever rotation for extra leg space •Lever adjustments for dash and seat clearance •Levers available in 32", 23", 16", 12", 10", 8" and 6" lengths* •Levers available in chrome-plated or black powder coat finish •Choice of Original Mushroom, Black Anodized Mushroom, Hi-Tech Lokar or Black Anodized Lokar Knob factory installed with shifters* •Teflon-lined shifter knob buttons for smooth operation •Easy to remove shifter knobs for simple boot installation •Gold iridited main plate and brackets •All hardware included •Accessory knobs available separately •Available for GM, Ford and Chrysler Automatic Transmissions* •Shifter Boots sold separately |
08-05-2012, 09:12 PM | #16 |
86 Scottsdale
Same thing I read. I think it will be fine with a bench.
08-05-2012, 09:15 PM | #17 |
08-05-2012, 09:17 PM | #18 |
86 Scottsdale
I am in if Frenchblue72 passes. He expressed interest first and I don't want to jump him.
08-05-2012, 09:26 PM | #19 |
Just to clarify. This does not come with the boot,and trim ring as they are sold new without them and i never got one for it.
08-05-2012, 09:35 PM | #20 |
PROJECT 7DEUCE
Im in just want to be sure it dont fit th350 as 2 were ahead of me..
08-05-2012, 09:49 PM | #21 |
The model numbers are different for the TH400 and TH350,so i would say for certain it only works on the TH400
08-05-2012, 10:20 PM | #22 |
No on the th350 I'll pass. Thanks
08-05-2012, 10:53 PM | #23 |
PROJECT 7DEUCE
Ill take it where do I send money?
08-05-2012, 11:25 PM | #24 |
08-06-2012, 07:04 PM | #25 |
PROJECT 7DEUCE
Pay pal sent thanks...
