06-22-2015, 04:07 PM | #1 |
Wizit's bagged 60 gmc build
Hey guys. Just started this build and figure i would document it for others to follow as well as to get some input from you guys. This place is obviously a wealth of knowledge!
Ill give you guys a little background on me since Im new here. Im 25 years old and live in Coeur d'Alene Idaho. (same as Captainfab) Im a design Engineer at a rollercoaster company called Rocky Mountain Construction. My fabrication and build background is almost completely from offroad rock crawler and go fast type rigs. I wasnt really in the market for another project but my brother came across a 1960 GMC that was incorrectly listed as a 63 Chevy on craigslist. He convinced me to go look at it and he actually ended up buying the truck for me in exchange for building his roll cage in his 66 Nova. I have always wanted to build one of these trucks so now im gonna get my chance. Here it is when we picked it up and when we got it home. Its really straight overall and nearly rust free. the only problem area we found was the drivers rocker. It has some kind of filler on it so Im assuming theres some rot in under there. The 305 was missing a carb but looks as if someone recently pulled it out and painted it up. the paint on the pulleys hasnt even been worn off from the belt so im not sure if they couldnt get it running after putting it back in or what. regardless, it will be getting a sbc and an auto tranny. Anyone interested in a non-running 305? lol The plan is to lay it out on 20s or maybe 22s. not going to be a show stopper but a garage paint job and body work will be plenty fancy for me.
Over the top, billet infused, ground up 60 GMC build http://6772chevytrucks.com/vboard/showthread.php?t=809901 |
06-22-2015, 04:29 PM | #2 |
Re: Wizit's bagged 60 gmc build
Welcome and great looking truck.
Very cool that you've got some fabricators and forum members close by and Captainfab is a wealth of knowledge on these trucks. Keep us posted on the updates and pictures!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
06-22-2015, 04:34 PM | #3 |
A guy local to me had a 60 Shortbed frame that had been modified with the X cut out and a later crossmember installed and a 63+ front end with drop springs. I got it and a 12 bolt rear from him for $200. We were already planning on cutting down to a shortbox so this was perfect.
Saturday my brother and I got the frame in the garage. First we cut the bottom of the crossmember and patched it in. I just laid a level across the frame rails and marked the crossmember. We added some gussets and some exhaust pass throughs. Started on the rear notch. The 60-62 frame doesnt have the jog in it like the later frames do so I just drew up a notch and cut it on one of our plasma tables at work. Prepping for the notch. Thats my brother grinding. Getting everything mocked up and tacked in. Pancaked the front crossmember 2" and somehow didnt take a picture of the finished product. We set the front end on it just to get a peek at what it was going to look like. Not bad for a days work. we are still about 2.5" from laying frame. Theres no drop blocks in the rear and the upper balljoints were maxed out. Im planning on building tube trailing arms with integrated blocks similar to the PB ones. The front I think I will Pie cut the upper arms and see where that gets me. Im trying to avoid drop spindles becasue this build is on a very very slim budget. The tires were deflated in this pic to get it to lay frame.
06-22-2015, 05:26 PM | #4 |
I have a foul mouth like sailor, so I have to say Golleeeee Gosh !!
You guys have hit it running. Amazing progress and vision of where you are going. I could never get up to all of this sort of thing, but I will be along for the ride. Ohhh, and welcome to you and your brother.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
03-21-2016, 01:29 AM | #5 |
03-21-2016, 08:23 AM | #6 |
Incredible fabrication skills! In for the build!
'66 GMC K25 (305 V6, SM420) aka "Mabel" Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082 All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado |
03-21-2016, 09:33 AM | #7 |
Very nice work!
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
03-21-2016, 10:00 AM | #8 | |
theres lots of info in the FAQ page. If you have a stock 62 crossmember with the torsion bars I dont think pancaking the crossmember is an option. I changed to a later style crossmember. Thanks guys! This thing should be coming home in the next couple months so there will be lots of progress happening soon!
06-22-2015, 05:20 PM | #9 |
SAVING ONE TRUCK AT A TIME
great start. welcome.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
06-22-2015, 09:50 PM | #10 |
and Welcome aboard to you and your brother!!!
I'm in too...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
06-22-2015, 10:37 PM | #11 |
I'm in for the ride!
06-22-2015, 11:40 PM | #12 |
let the air out to lay frame, why didnt I think of doing it that way?! engineers always work smarter not harder. (I am an engineer too)
did you hear about the engineer who got a call at work from his wife? she told him to stop at the store on the way home and pick up a loaf of bread, and if they had eggs to get a dozen. he went home with a dozen loaves of bread, looked her in the eye and said "they had eggs". looks like a great start! living in coeur d'alene, work for a roller coaster company, and have a slammed 60 gmc, three out of three aint bad!
06-23-2015, 07:59 AM | #13 |
thats a pretty good one Joedoh...
nice beginnings on the Jimmy guys and welcome. |
06-23-2015, 09:43 AM | #14 |
Welcome and nice start! I'm always interested in budget builds. Having a plasma cutter around doesn't hurt either!
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
06-23-2015, 10:31 AM | #15 | |||
06-23-2015, 10:46 AM | #16 |
I didnt do too much last night other than start planning a pie cut on the pper arms to help balljoint angle. so ill show you guys a little bit of where I got my start in fabrication and builds.
Everything I build is done in my 2 car garage and 98% of the work is done by me alone. Im kind of independent that way. Heres my main offroad jeep that I have owned since i was 18. It has been through many different builds and this is the latest. One ton axles full hydraulic steering 2002 yukon 5.3 vortec built th350 Atlas trasnfercase 42" Pitbull Rocker Tires 20" ATX Alloy beadlocks etc etc Heres a 72 Datsun 240Z I built for fun a couple years ago.
06-24-2015, 02:59 PM | #17 |
Senior Enthusiast
Very impressive progress! Nice to have the skills, drive, planning, and work tools available to dive right in on something this substantial. Beautiful welding on the crossmember, and the professional computer drawings certainly must be a benefit. Welcome to the forum!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
06-24-2015, 03:55 PM | #18 |
bad ass datsun...
06-25-2015, 02:04 AM | #19 |
I agaree, love that colour too.
The guys on here would love your builds...... You could register and copy n paste. The Datsun would sooooo fit in there. http://retrorides.proboards.com/board/12/readers-rides I have an almost duplicate of my truck thread on there too. Copy n paste makes it easier. I am in awe that you build 98% solo.
06-24-2015, 04:00 PM | #20 | |
I have background in design, fabrication, and machining which adds up to being able to build nearly anything I need. Its rare that I buy components rather than build them. Having access to our cnc plasma tables at work in addition to my hand plasma is a giant plus!
Over the top, billet infused, ground up 60 GMC build http://6772chevytrucks.com/vboard/showthread.php?t=809901 Last edited by Wizit247; 06-24-2015 at 04:15 PM. |
06-24-2015, 11:38 PM | #21 |
Super cool project. Keep it rolling along.
The Snortin' Bull |
06-25-2015, 09:30 AM | #22 |
Off to a nice start and nice rig. I have a TJ on 35"s with air lockers etc....
A bunch of my buddies are serious into crawling and a few of my other friends have huge 2.5 ton and 5 ton mud trucks. I'm in for this one
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
06-25-2015, 10:00 AM | #23 | |
Thanks! I plan to move through this fairly quickly so it should be a fun ride!
Its always nice to meet other offroad guys. We are usually all the same kind of crazy. lol! I have a build thread of the v8 swap of my Jeep over on Pirate4x4 if your ever over there.
06-25-2015, 10:08 AM | #24 |
I got the trailing arms built last night!
I cut and tacked on some new brackets for the bushings so they have the correct width and bolt hole size. The tube is 1.75 x .188 wall so it should be plenty strong to put the bag mounts on. The rear end now lays frame with tons of room to spare. Does anybody know where I can get ubolts that are really short or have thread that goes almost full length? They only have to pass through two pieces of 1/4" steel now rather than the 4" or so thick trailing arm so factory ones are way too long! The only place that makes them around here is an hour away from me.
06-25-2015, 10:31 AM | #25 |
Looking good! sweet datsun man!
